Fuel pump ID
Old Apr 1, 2005 | 03:49 AM
bk2w's Avatar
bk2w
Default Fuel pump ID
I started rebuilding the fuel pump from my '58 yesterday. Once I got it apart, I discovered that it doesn't match the rebuild kit I got from Zip.
Specifically, the kit has six small valves while the pump had too larger. The bearing, pin and lever arm from the kit are all significantly different sizes. The main diaphragm spring from the kit is also significantly larger is diameter than the pump's.
The inside of the pump housing has a casting number of 5621037.
Any ideas what year my pump is from?
Here are the parts as disassembled (and cleaned) from the old pump:
Thanks,
-Brian
Old Apr 1, 2005 | 07:05 AM
tentuna's Avatar
tentuna
Default Reply Pump
The PN for the pump is on the one of the vertical mounting flanges
Old Apr 1, 2005 | 08:46 AM
vark_wso's Avatar
vark_wso
Looks like it might be 40083 (180 degree inlet/outlet port configuration & the bottom cover attached with 2 machine screws). Check for a stamping on the angled mounting flange -- should have 4 or 5 numbers there. If it is 40083, '66 327/350HP is one application.
Old Apr 1, 2005 | 02:42 PM
bk2w's Avatar
bk2w
Looks like "4663" is cast on the mounting flange.
-Brian
Old Aug 26, 2010 | 10:09 PM
92GTA's Avatar
92GTA
Let's bring this sucker back to life
I too have a 4663 fuel pump that I am trying to figure out it's applications so I can sell it...
Thanks!
Alex
Old Sep 27, 2010 | 04:35 PM
92GTA's Avatar
92GTA
Bump to figure out what applications the 4663 pump is for...
Old Sep 27, 2010 | 06:11 PM
Plasticman's Avatar
Plasticman
Don't find a Corvette application for a 4663 fuel pump.
Plasticman
Old Sep 27, 2010 | 07:34 PM
92GTA's Avatar
92GTA
Plasticman
Ok, thanks for checking! It needs a rebuilt so I'll just toss it then I guess.
Thanks!
Alex
To Fuel pump ID
