Why??????
Old Apr 3, 2005 | 10:46 PM
bj1160's Avatar
bj1160
Default Why??????
My temp ga. and fuel ga. seem to have a short . They only work intermittently I have checked under dash behind instrument panel for loose wires or anything that might cause a problem to no avail. I turn the ignition over today thinking it was in neutral but it was in gear when it lundged the gauges worked for a while. Could it be the ign. switch.? Any help would be great it is a 67 427/390. L36
B
Old Apr 4, 2005 | 11:42 AM
JohnZ's Avatar
JohnZ
The circuit that feeds power to the temp and fuel gauges also feeds the backup lights, fuel tank sending unit, and the parking brake warning lamp in the cluster; do they work? That circuit is the only one fed from the top fuse in the fuse block. Those two gauges also require a ground to the cluster to work; if the cluster isn't properly grounded, the illumination bulbs, wipers, and lighter won't work either.
Old Apr 5, 2005 | 08:40 AM
bj1160's Avatar
bj1160
The ill. bulbs, wipers, and lighter work but not back up light and not parking brake warn light.
Brian
Old Apr 5, 2005 | 11:06 AM
JohnZ's Avatar
JohnZ
Brian
Check the top fuse in the fuse block - everything you have that's not working is fed from that fuse.
Old Apr 5, 2005 | 06:57 PM
bj1160's Avatar
bj1160
That was the first thing I checked. This has got me stumped.
B
To Why??????
