Muncie drain plug install
Old Apr 8, 2005 | 09:26 AM
Brutal64's Avatar
Brutal64
Default Muncie drain plug install
For those of you that have installed a drain plug in their transmission, what thread size did you use and where did you place the plug?
Old Apr 8, 2005 | 11:47 AM
67L36Driver's Avatar
67L36Driver
3/8" NPT at the boss on pass side. Use a drill press for sure. Not to be attempted while trans is in car.
Old Apr 8, 2005 | 12:54 PM
GTR1999's Avatar
GTR1999
I installed one in the front base. I used a 1/4" NPT but bushed it down to 1/8 NPT so i don't "work" the aluminum threads all the time.
Gary
Old Apr 8, 2005 | 05:14 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
3/8 NPT ...I drilled while my 66 was on my friends lift.... ... the warm trans fliuid washed out all the shavings.........worked for me....................the Dog.
Old Apr 8, 2005 | 08:19 PM
Plasticman's Avatar
Plasticman
Think that the trans fluid would wash out the drill shavings, but what about the tap shavings? Think you would need to flush a little more fluid through there after the tapping operation. But, the aluminum from the case is pretty soft (compared with the rest of the materials inside), so even a stray piece should not harm the internals of the trans.
Plasticman
Old Apr 8, 2005 | 10:25 PM
GTR1999's Avatar
GTR1999
I did the job while rebuilding the tranny and the case was empty.
Gary
To Muncie drain plug install
