Rear Leaf...
Old Apr 9, 2005 | 08:48 PM
SPLITRAY's Avatar
SPLITRAY
Default Rear Leaf...
My 63', 7 leaf spring has metal or tin liners in it. Is this original? I've seen adds saying "OEM replacement plastic liners"! I didn't even think that technology was available then.
In fact I have a 7-leaf with a spacer block, instead of the more common 9-leaf springs that I see advertised in the catalogs. Has my spring been modified or were there original 7-leafs out there? The original car was an L-76.
Mike
Old Apr 9, 2005 | 11:01 PM
SWCDuke's Avatar
SWCDuke
Yes, the spring liners were a graphite impregnated plastic going all the way back to '63, but they compress, wear, and harden to something that looks more like old leather.
Your rear spring is not original as the only way a '63 was built with the seven leaf rear spring is if it was equipped with RPO Z06, which included L-84 and the HD drum brakes that can't be confused with anyting else.
Duke
Old Apr 10, 2005 | 07:00 PM
JohnZ's Avatar
JohnZ
Non-Z06 63's all had nine-leaf springs, with all nine leaves cambered (arched); the '64-up standard spring was a different nine-leaf, with the top three leaves flat. Where is the "spacer block" located, and what hex size are the four spring-to-rear cover bolts?
Old Apr 16, 2005 | 06:24 PM
SPLITRAY's Avatar
SPLITRAY
Default JohnZ
The spacer is 1" thick and is located between the spring and the carrier. The bolts that secure the entire assembly are grade 5, 9/16" X 4-1/2" long.
Mike
Old Apr 16, 2005 | 06:34 PM
67L36Driver's Avatar
67L36Driver
Someone tried to raise rear of car? Attempt to fit larger tires way back when?
Old Apr 16, 2005 | 07:33 PM
SPLITRAY's Avatar
SPLITRAY
Default Look @ my Avatar.
The car in my Avatar and the pix in "my photo's" is the way the car sits with the 7-leaf configuration and the spacer block. I always thought it was kinda low, and I like the stance.
The car did have 8" X 15" monte-carlo rims when I got it, but height clearance wasn't an issue in the rear. The spring ends actually dragged inside the wheel. I changed to 6" X 15" rims because of front clearance issues.
Do 7-leaf springs typically NOT have a spacer?
Mike
Old Apr 16, 2005 | 10:36 PM
SWCDuke's Avatar
SWCDuke
No spacer. The HD seven leaf spring also lowers the ride height - up to about an inch, from the base suspension 9-leaf spring.
The HD 7-leaf spring was meant strictly for racing. The combination of double the wheel rate and lower ride height don't make it street friendly at all.
Duke
Old Apr 17, 2005 | 12:19 PM
JohnZ's Avatar
JohnZ
Mike
Is the spacer forward of the spring (between the front side of the spring and the carrier, or is it above or below the spring? Is 9/16" the hex size of the bolts, or is it the thread size (13/16" hex)?
Old Apr 17, 2005 | 04:43 PM
SPLITRAY's Avatar
SPLITRAY
Default JohnZ
The aluminum spacer (6"lg x 2-1/4"wd x 1"thk) fits squarely above the top of the spring (it is centered over the spring). It is centered over the the top unbent leaf (7"lg), and has a recess for the spring bolt. The spacer also has a bolt just like the spring that fits into the carrier where the spring bolt would normally go. I am assuming that the top unbent 7" x 2-1/4" plate is not actually counted as a leaf.
It looked so much like it was original that it never occured to me that it didn't belong there. The bolt in the spacer is even drilled and tapped and the hex is ground off to fit in the carrier. I would have expected just a piece of round stock just stuck in there if it were Bubba'd.
The bolts are 9/16" NC thread size. I don't know if this makes any difference, but the differential is from a 67'. Don't know about the spring. I will post a picture of the previously assembled setup with "my corvette photos".
Not quite sure what to do now other than just put every thing back as it was??? Don't know what to expect if I get a 9-leaf? How thick is a 9-leaf at the mounting? What would you recommend?
Mike S.
Old Apr 18, 2005 | 03:04 PM
SPLITRAY's Avatar
SPLITRAY
Default JohnZ
That photo of the rear leaf set up before I took it apart was approved and is in "my corvette photos" If you want to take a look at it.
Mike
Old Apr 18, 2005 | 04:10 PM
JohnZ's Avatar
JohnZ
Mike, that spacer block in the photo was apparently added to increase the rear ride height, with longer bolts added; the stock spring retainer plate bolts are 3-9/16" long with the 9-leaf spring, and 3-5/16" long with the HD 7-leaf spring (there's a 1/4" difference in the stack height of the two springs). Must have been a "fix" for incorrect ride height produced by the (also incorrect) reproduction rear spring. The '67 diff makes no difference - the diffs and rear covers were the same (dimensionally) from '63-'77. If you need a mostly-correct '63-style spring (nine leaves, all cambered), Eaton Detroit Spring (www.eatonsprings.com) has them.
Old Apr 18, 2005 | 06:06 PM
SPLITRAY's Avatar
SPLITRAY
Default Thanks A lot John
I think I will inquire with Eaton about getting the correct front and rear springs, then finish the suspension parts build up based on that.
Mike
To Rear Leaf...
