Missing ignition shielding
My 67 small block, which has the radio delete option, is missing almost all of the ignition shielding (only has the distributor / coil cover). Does anyone know if radio delete should include full shielding ?
I would like to add the vertical pieces that connect to the distributor cover, but I don't see what the bottom of the right hand vertical cover attaches to. The left vertical cover seems to attach to the left side spark plug wire support that bolts to the block - but not the right side
The right vertical attaches to the right hand horizontal spark plug cover shield.
