Broken hood release cable
I know I read a thread a few months ago how to open the hood with a broom handle from underneath, but searched the old threads and could not find the information.Anyone have a remedy to open the hood with a broken cable????
HELP!
Ron
It was a charity event for Habitat for Humanity.
I had just rebuilt the engine, and got it back on the road.
The engine compartment was immaculate, but the outside of the car looked rough (still does). I pulled into my spot in a grass field, and went to pop the hood to show off all my hard work, and nothing. The handle came off in my hand. Some guy came by and asked me if the engine was still in the car.
Anyway, I called my wife, went home and got a jack, a flashlight, and a long screwdriver, and got the hood open.
There wasn't any trick, and I didn't need a broom handle.
Just pry open the hood latching mechanism on both sides.
You can get to it from underneath the car, if your arms are long and thin enough. Even in a grass field.
If neither latch releases on yours - it was probably the cable from the handle to the left side latch that broke. You'll need to remove the driver's side splash shield and push the lever on the bottom of the latch rearward (toward the firewall). That should release both sides.
I couldn't quite reach the releases by hand - a short pry bar did the trick.
Thom
