Mixing Oils
Duke
Don't doubt that you may get some other opinions, though. But these are my thoughts and observations.
Duke
brian
API CI-4! That's all that counts.
The commonly available multi-vis CI-4s are 15W-40, which is suitable for cold starts from about 10F to over 100F. I know that Delo is also available in 10W-30 if you drive your car at temperatures below about 10F, but I've never seen it in stock at any local outlets.
There is no harm in mixing any API service categories (including any "C-" or "S-") to include synthetic or mineral base oils. Basically all automotive motor oils are compatible.
Modern motor oil additives are all essentially the same. It's just that the current CI-4 oils and some older "S-" classifications have higher concentrations of some additives than modern SL or SM oils. Also, newer mineral oil base stocks have higher oxidation resistance than some of the older service categories, but that's not a reason not to use an older service category oil if you have some in inventory.(Actually, many "conventional" mineral based oils have some synthetic base in them to meet the minimum oxidation resistance requirements for all current API grades.) Oxidation of the base stock is a primarly cause of sludging, which is much less frequent nowadays than in the past. Some modern cars have had a sludging problem, and it's likely caused by either inadequate crankcase ventilation or too high oil temperatures in normal driving, and in most cases it may be due to owner inattention to proper change intervals for their driving habits.
My two modern cars have oil capacities of 4.5 and 6.3 quarts, respectively, and I use 15W-40 Delo for the last fractional quart with the even quarts of whatever API SL or SM 20W-50 I happen to be using, which is whatever national brand was on sale that last time I bought a case!
Back in the sixties the recommended oil change interval was 6000 miles or 60 days, but modern CI-4 oils on occasionally driven Corvettes are okay for a year assuming you drive a few hundred to a few thousand miles per year.
If you store the car during winter, change the oil just before storage. The clock doesn't run on fresh oil in the crankcase while the car is in storage. Since most of us probably drive our cars least in winter, a fall oil change at the end of the high driving season is probably best if you drive your Corvette year round.
I've never used Marvel Mystery Oil, so I have no opinion other than I never use any supplemental additives in any fluids in any of my cars. If you use the correct fluid, you don't need supplemental additives.
Chevron Techron is an excellent fuel additive for cleaning intake system and injector deposits, but it's only needed if the car develops some driveability problems that indicate injector or valve deposits.
There are also some additives that have a very high dose of detergent to free sticky rings or hydraulic lifters, but if you use CI-4 oil on a reasonable change frequency, this won't happen, and if a modern car develops the problem, a load of CI-4 oil for one interval will often free things up.
Duke
Over the years, filter media have improved, so I see no reason not to continue using the replaceable cartridge filter on vintage Corvettes since they use modern filter media that meet current OE and SAE requirements for automotive oil filters.
The research papers indicated that particle generation is primarily an engine break-in phenomenon. Once this is complete, very few particles are generated until the engine approaches end of life and the wear rate accelerates. This implies that changing the filter with every oil change may not be necessary, especially if the engine sees low mileage accumulation between oil changes. In the case of a vintage Corvette, you could just remove the cannister, empty it - to remove all the old oil - fill it with fresh oil (I do this because it takes less time for pressure to come up on startup because the pump does not have to fill the filter), and reinstall.
The above also implies that it would be a good idea to change the filter after the first few hundred miles on a new car, eventhough OEMs don't typically don't recommend this, but the factory fill oil is okay for the full recommended service inteval.
A couple of my cars have "upside down" filters, and in order to avoid spilling oil when they are removed I puncture the top of them which allows the oil to drain down. This precludes their reuse, so they have to be replaced, and given the cost and convenience of just installing a new spin on filter or cartridge I always change the filter as SOP - not necessarily because the filter needs replacement, but just of ensure that as much of the old oil as possible is removed.
Duke
