Help needed: Problem with FI
Old May 12, 2005 | 04:16 PM
CoolShark's Avatar
CoolShark
Default Help needed: Problem with FI
I have a '63 FI unit that was overhauled in '87 and worked great. Suddenly it won't idle well. I have tried adjusting the idle RPM's, but that makes it idle too high. It still runs great on the road.
Old May 12, 2005 | 06:07 PM
jerrybramlett's Avatar
jerrybramlett
I would check the Cranking Signal Valve on the front of the fuel meter.
Replace the short hose attaching it to the tubing from the main diaphragm with a 1' long section of vacuum hose. After starting the car, pinch that hose positively shut with a small C-clamp. If the CSV is working properly, this will have no effect on your idle quality. But if the unit will then idle like it used to....
