Looking for electrical help
Old May 22, 2005 | 12:34 PM
76rich's Avatar
76rich
Default Looking for electrical help
Out of the blue I am having tailight problems. This is not a new wire situation, but all wires are very pliable and clean. Driverside tailghts light up like they should, but when brake is applied, outer light goes out. When blinker is on instead of both blinking, one blinks then the other blinks. I have tried different bulbs, but to no avail. Due to my work schedule I don't have a lot of time to diagnose and I was hoping someone else has gotten through this problem before. By the way the front parking light works and blinks as should.
Thanks,
Richard
Old May 22, 2005 | 06:30 PM
Hitch's Avatar
Hitch
Sounds like your turn signal switch assy in your steering column is shot.... Dave...
Old May 22, 2005 | 07:08 PM
TJefferson2020's Avatar
TJefferson2020
You might have two problems going on at once here. The brake lights are simple - a wire goes from the brake switch under the dash (the brake pedal activates it) to the bulbs in the rear. I believe it gets it's power from the turn sig switch in the column. Use a multi meter set to ohms and check for continuity - could be a wire grounding out somewhere between the switch and the light that goes out. (assuming the bulb is good.)
Then, the turn sig problem is probably the turn sig switch - I would also make sure you don't have a bad flasher (those little silver cans attached the the fuse box) Replace those because they are cheap. Make sure you get the right one.
Otherwise, replace the turn sig switch - it's about $75 but after 40+ years it could probably use a new one anyway.
Old May 22, 2005 | 07:34 PM
RichF's Avatar
RichF
St. Jude Donor '03, '04 & '05
Check for good grounds.
Old May 22, 2005 | 07:58 PM
vref's Avatar
vref
Sounds more like a grounding problem, the circuit is trying to ground thru the light bulbs themselves, hence the other lights illuminate when the pedal is depressed.
Old May 22, 2005 | 08:05 PM
Hitch's Avatar
Hitch
Right... Well all of the turn signal power and brake light power circuit is contained in the turn signal assy... If you replace the turn signal assy your problem "should be solved..."
Old May 23, 2005 | 12:09 AM
K2's Avatar
K2
Sounds like the Classic and common (for Corvettes) grounding gremlins. Check and clean all your grounding connections. You must have a good clean connection to the frame and at the front between engine and frame as battery ground strap most likely is attached to engine block.
Old May 23, 2005 | 12:58 AM
00fxd's Avatar
00fxd
My car was doing exactly the same thing last summer. The pigtail that twists into the socket from the harness was not seating correctly. It was backfeeding causing alternating flashing. I did some adjustments and did not have to change anything. I'm pretty good with electrical. I had 1/2 the car apart checkin' stuff. I felt kinda dumb but it was a tricky one. Remove the pigtail from the socket and use a test light at the pigtail to check.
Old May 23, 2005 | 08:27 AM
76rich's Avatar
76rich
Thanks for all the replies. 00fxd, this sounds like it might be the ticket. A couple of years ago I replaced all grounds with new ones and I only drive this car a few hundred miles per year, so I really think the problem might be in the tailight assembly itself. I had it apart and it is very cleanand looks good. I will start there and move on to grounds and if I have to I will go into the turn signal assembly.
Richard
Old May 23, 2005 | 01:16 PM
00fxd's Avatar
00fxd
If you look there all might look fine. The key is to remove the pigtail from the socket and check for correct operation at the pigtail with a grounded test light. I don't know why I didn't do this first when I had my problem. It's easy to do once you remove the lower body valence. I was condeming the turn sig switch and worked from that direction.
Let us know what you find.
To Looking for electrical help
