First Ride
What a difference from the 300hp configuration! With the M20 trans and 3.36 rear, the car takes off effortlessly. Once on the gas, the difference was nothing short of amazing. Great power throughout the RPM range. About scared myself when I opened it up. First, I thought I was slipping the clutch during the 1-2 shift only to figure out it was the tires spinning. Then came the 2-3 shift when the car went completely sideways.
Guess my rudimentary alignment needs some professional help. After a couple of runs up and down the street (back road, no kids), I put it away before I hurt myself.Power steering worked perfectly, brakes whoa'd me down without any pulling, rode real smooth with the new Bilstein HD's.
A couple of small things to finish it up, and should be 100% roadworthy by next weekend.
Yup, I'm a happy camper....
Lines from the Beach Boy's song "little deuce coupe" come to mind!
I get pushed out of shape
and it's hard to steer
when I get rubber in all four gears
you must have built that L76 right!
From setting the valves, timing and distributer, having the carb rebuilt and flow tested by an outfit that got it right, cooling, proper placement of various items on the engine, body mount tips, suspension tips...... And most everything is as GM engineered it to begin with. Everything worked the first time.
I'm still surprised how quiet the mechanical lifters are when adjusted correctly. I can remember some of my older creations that clattered loudly.
Is this fun or what?
(Brian Wilson/Roger Christian)
Tach it up, tach it up
Buddy gonna shut you down
It happened on the strip where the road is wide
(Oooo rev it up now)
Two cool shorts standin' side by side
Yeah, my fuel injected Stingray and a four-thirteen
Revvin' up our engines and it sounds real mean
Tach it up, tach it up, tach it up
Declinin' numbers at an even rate
(Oooo movin' out now)
At the count of one we both accelerate
My Stingray is light the slicks are startin' to spin
But the four-thirteen's really diggin' in
Gotta be cool now power shift here we go
Superstock Dart is windin' out in low
But my fuel injected Stingray's really startin' to go
To get the traction I'm ridin' the clutch
My pressure plate's burnin' that machine's too much
Pedal's to the floor hear the dual quads drink
(Oooo pump it up now)
And now the four-thirteen's lead is startin' to shrink
He's hot with ram induction but it's understood
I got a fuel injected engine sittin' under my hood
Shut it off, shut it off buddy now I shut you down
The 413 is the same basic engine as the 440 and was extremely successful on the Nascar circuit. We all remember Richard Petty #43 in that '63 Plymouth.
Congratulations! The 413 is the same basic engine as the 440 and was extremely successful on the Nascar circuit. We all remember Richard Petty #43 in that '63 Plymouth.
Nothing like enjoying the fruits of your labor.
I always have a Sh-t eatin grin on my face when I take my 65 SB convt out with the top down.
Can't wait to finish my 65 BB Coupe.
I'll stop by and see you at Carlisle. We, my wife, my big Akita and I spend the weekend there every year.
Enjoy your ride
Dennis
