66 Alternator/Regulator
Old May 27, 2005 | 09:22 AM
Dennis Beck's Avatar
Dennis Beck
Default 66 Alternator/Regulator
I replaced my alternator in my 66 when I did my engine swap with an 80 amp model. Last night while driving my battery guage would be at +40 when the engine rpm was up and at 0 when the engine was at idle. I went home and put my old alternator back on and had the same problem. I then tapped the regulator slightly and the guage returned to normal operation. I went for another ride and the same thing occured once again. This regulator is probably the original. My question is could an 80 amp alternator be too large and cause the regulator to fail? NAPA has a regulator for a 66 #VR142SB that is rated for a 63 amp alternator. I am going to put that regulator on the car tonight. Do you think this new regulator will handle an 80 amp alternator?
Old May 27, 2005 | 09:37 AM
67L36Driver's Avatar
67L36Driver
Get a new replacement solid state regulator form any parts store. Cost will be 10-20 bucks.
Take that old mechanical contact POS and put it on the shelf for the next owner.
Do this before you cook the s%&t out of your battery.
magicv8's Avatar
magicv8
IMO - no. I installed a transistor regulator supplied by a FL company that I found on the web. They have a heavy duty regulator used for high amp (truck) duty. They do not sell direct to the public. After you get the make and model number of the reg, you can ask them to identify a local vendor.
A thread search may turn up the name of the supplier. If not, I'll dig up the name of the reciept.
Old May 27, 2005 | 09:41 AM
Dennis Beck
Default Wiring
With a solid state regulator will my wiring harness plug at the regulator (4 pins) match the new regulator?
Old May 27, 2005 | 09:44 AM
magicv8's Avatar
magicv8
Yes, and you can even put your delco remy cover on it if the blank cover offends.
Old May 27, 2005 | 10:24 AM
Dennis Beck
Thanks this sounds like a good upgrade. I will start calling around to find one.
Old May 27, 2005 | 12:48 PM
Tyler Townsley's Avatar
Tyler Townsley
You can take the stock alternator to a good alternator shop and they can change the internals to a 105 Amp unit. The advantage of this is it still looks stock. I have one on my 68 and 66. I have the stock regulator in the 68 and one of the newer electronic types on the 66. I drive the 66 most every day and have had no problems.
Tyler
Old May 28, 2005 | 09:58 AM
magicv8's Avatar
magicv8
My solid state regulator is made by Transpo. The box has the number D9212S on it
I believe the S sufix is the heavy duty version of D9212
To 66 Alternator/Regulator
