Electric headlight conversion
May 27, 2005 | 01:36 PM
From: You are here to build strength, not demonstrate it
St. Jude Donor '08
Dad has a 65
and having alot of trouble with the headlight up & down.
anyone here in C2 done an electric conversion?
Pros & cons
Thanx!!
May 27, 2005 | 01:43 PM
What do you mean electric conversion??? The motors on 1963-67 are electric. You can get them rebuilds pretty cheap.
May 27, 2005 | 02:19 PM
St. Jude Donor '08
Guess I win the dunce award of the week.
My 72 has given me headache after headache, and I know electric conversions are available.
I really thought they were vacuum in 65 also.
Sorry.
I'll tell Pop to get a new motor
May 27, 2005 | 04:11 PM
Quote:
Originally Posted by markyerger
Dad has a 65
Pros & cons
Thanx!!
Try going to:
http://65corvette.nonethewiser.net/t...or_Rebuild.pdf
Very quick and painless (and funny) site that shows how to rebuild the headlight motors. And it doesn't cost you alot of money
Reason: URL was wacked...
May 28, 2005 | 02:46 PM
Has anybody rebuilt the headlight up/down swith under the dash?
May 28, 2005 | 06:44 PM
St. Jude Donor '13-'14-'15-'16
Quote:
I did mine. A very simple job. should take less than 30 minutes
2 Clips hold it together, lift them
GENTLY
separate the housing from the back plate
clean the contacts on the switch lever and the contact points in the housing. A little emery cloth will work well.
lubricate with di-electric grease
re-assemble
install back to dash and connect harness
May 28, 2005 | 10:30 PM
thanks, i'll give it a shot.
1964 ,
1991 ,
65 ,
c4 ,
conversion ,
corvette ,
electric ,
front ,
headlight ,
modification ,
upgrade
