Automatic chole wiring problems
Old Jun 7, 2005 | 02:51 PM
65-vette's Avatar
65-vette
Default Automatic chole wiring problems
I have checked the wiring schematics for the 65 vette but have not seen any mention about wiring for an auto-choke. Maybe, that was not an offering for that year. Anyway, I have installed a Holley 4150 on my 327, now I need to wire up the choke. Any suggestions as how I need to go about this?
Thanks in advance........
Old Jun 7, 2005 | 04:14 PM
ctjackster's Avatar
ctjackster
pull power from the 12v side of the resistor on the firewall for your electric choke.
Old Jun 7, 2005 | 04:22 PM
JAF1's Avatar
JAF1
Should be the bottom terminal but check with a meter to be sure. Also, don't forget an inline fuse.
Old Jun 7, 2005 | 07:49 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
On my `65 there was an unused switched L shaped terminal on the firewall just below and to the driver's side of the wiper motor. The spade from the electric choke plugged into one side of it without any mods.
Old Jun 8, 2005 | 01:45 PM
65-vette's Avatar
65-vette
Thanks guys for the help.
Mike
Old Jun 8, 2005 | 02:16 PM
JohnZ's Avatar
JohnZ
The full 12V side of the resistor has the pink wire on it that comes through the rubber grommet in the firewall; the other (reduced-voltage) end has a pink wire that comes out of the engine harness above the wiper motor.
To Automatic chole wiring problems
