Quick help needed
Old Jun 17, 2005 | 07:24 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Default Quick help needed
Can anyone give me the float level settings for a 65 AFB Carter # 3721sb. I've got my carb apart at work and (dummy me) I left the spec sheet at home
Old Jun 17, 2005 | 08:00 PM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
pmullaly,
Was just on the bottom of the page on carburetors in my '65 supplement. The correct AFB (3721 SA)...manual trans Float Level settings are:
Primary: 7/32"
Secondary: 7/32"
Good luck!
Jim
Old Jun 17, 2005 | 10:42 PM
AzMotorhead
Jim I think that might be for a Holley.
AFB's floats are hung to each side of Venturi's. Left and right bowls feed both the primary and secondary. Float settings should have a upper stop setting like 7/16 and a float drop of around 1.1/4.
Thanks for looking
To Quick help needed
