Ignition switch
Old Jul 10, 2005 | 03:40 PM
FINWOLF's Avatar
FINWOLF
Default Ignition switch
Here is my problem. put the key in and turn it and it starts. thats good then when i go to turn it off the motor just keeps running. befor i take it a part what do you think I should look for. thanks guys
Old Jul 10, 2005 | 07:22 PM
sjaroslo's Avatar
sjaroslo
From: And make no mistake, there's women who just wait for the man and machine with the best time
St. Jude Donor '08
Do you have an MSD ignition? I don't remember the details but mine came with a diode that was required if one experienced the problem you are describing. I think that there was just enough current that came through the alternator or ammeter circuit that the ignition could keep running with the key turned off. Just a thought.
Old Jul 10, 2005 | 07:39 PM
FINWOLF's Avatar
FINWOLF
No it is the stock 1965 ignition.
Old Jul 10, 2005 | 09:33 PM
magicv8's Avatar
magicv8
Put a voltmeter on the coil and tell us if it has 12volts all the time when the points are open or 12-14 when the engine is running. If so the solenoid (12volt start circuit) wire is providing power. In that case the solenoid may be bad, but my guess is that the starter wiring is fried and the pink wire is fried to one of the 12volt battery wires.
If the coil has less than 12 volts, it is coming from the pink ignition line from the key switch through the ballast resistor that lowers the voltage for running (as opposed to starting).
Old Jul 11, 2005 | 01:07 PM
FINWOLF's Avatar
FINWOLF
went out to day and all works put the key in it starts and turn the key off and it stops.
Old Jul 11, 2005 | 07:58 PM
62fuelie's Avatar
62fuelie
Check the solenoid. Sounds like something is getting hot and sticking.
Old Jul 11, 2005 | 09:26 PM
FINWOLF's Avatar
FINWOLF
ok i will check it out.
To Ignition switch
