Engine won't start???
Old Jul 15, 2005 | 07:14 PM
odqlesz's Avatar
odqlesz
Default Engine won't start???
Here's the details:
- have gas
- have spark
- engine freshly rebuilt
- I installed the distributor, may be a problem with timing?
#1 at top, dropped dist. facing #1 plug wire on cap.
When I crank, it will back fire out the exhaust and
spit out of the carb but won't start.
Tried adjusting the timing, one way I still got the backfiring(towards the dist) the other way, it just cranked and did nothing, no backfire.
Afraid to crank any more as to cause problems.
Old Jul 15, 2005 | 07:19 PM
vette rod's Avatar
vette rod
sounds like the timing is 180 off.
www.pugesekmotorsports.com
Old Jul 15, 2005 | 07:26 PM
odqlesz's Avatar
odqlesz
I know that dimple on the shaft is facing #1 so does that mean
it's not 180 off?
The shop that rebuilt it rotated the engine to set up #1 as to
all i had to do was to drop in the dist. He turned it manually where
#1 plug had pressure comming out and stopped it on the zero timing
mark.
Old Jul 15, 2005 | 07:31 PM
67L36Driver's Avatar
67L36Driver
Sounds like the classic 180* off. Also might check the 'witness marks' on the damper line up (very hard to see, even with the thing in front of you). BB uses a triangle and a dimple.
Keep crankin' as it won't cause mechanical damage. Keep an old blanket handy to smother carb fires.
Old Jul 15, 2005 | 07:32 PM
VFW NO.11548's Avatar
VFW NO.11548
the cam position dictates what is firing....you are firing most likely no. 6 , pull distr and drop it in with the rotor pointing at no. 6 plug wire (180 degrees off)
Old Jul 15, 2005 | 08:21 PM
odqlesz's Avatar
odqlesz
Ok, did it. No backfiring, but the carb is still spitting and still
won't start. The more i pump the pedal, the more the carb spits.
Old Jul 15, 2005 | 09:26 PM
SWCDuke's Avatar
SWCDuke
Year? BB? SB? Point ignition? TI? It helps to know these things when doing a diagnosis.
Place the engine at the initial timing point (NOT TDC) on the #1 cylinder. Pull the plug and feel for compression to be sure #1 is on the compression stroke.
Remove the distributor and check that the dimple is pointed in the same direction as the rotor tip.
Further instructions may follow if you answer the questions.
Do you have a service manual for your car?
Duke
Old Jul 15, 2005 | 09:43 PM
ctjackster's Avatar
ctjackster
you may be a tooth off, sounds like you are able to get it close by rotating the dist - suggest reinstalling dist one tooth forward or backward. Another way to try this is to walk your spark plug wires around the cap one position at a time - but don't let JohnZ or Duke hear about it - re-indexing dist caps is not one of their favorite things, but it would eventually get you to running condition. shhhhhhhhh, mums the word (and no one will ever know once you put the big shielding pice back on . . . .)
Old Jul 15, 2005 | 09:45 PM
odqlesz's Avatar
odqlesz
Duke
67 SB Points 350hp
Just to verify a few things, when you say place the engine
at the initial timing point,
the book says 10 B, so the mark on the balancer should be
at 10 Before. The timing tab has marks A O R each line represents
2 degrees right?
So should go towards the A side or R side. I'm thinking A side since
the engine turns clock wise and the A is before the O.
I will pull the dist. and wait for your answers to the above before
installing it again.
Thanks alot for all your knowledge.
Oh, yes I do have a service manual for the 67.
Read it and now i'm looking at How to rebuild your Chevy small block
book.
Ok, i just read "Setting the ignition timing" that answers my questions above. Here we go again.
Old Jul 15, 2005 | 11:56 PM
SWCDuke's Avatar
SWCDuke
Reading the service manual always helps, eh!
1. Set the balancer notch at "A" on the tab (which is 10 deg. BTC) with the engine on the #1 compression stroke.
2. Pull the dist and verify that the dimple is pointing in the same direction as the rotor tip. Rotate 180 degrees if required.
3. Verify that the #1 wire is indexed on the proper terminal on the cap IAW the shop manual diagram and then goes CCW in the firing order.
4. Install dist with the rotor about 45 degrees to the right of vehicle centerline. You may have to tweak the oil pump drive. When seated the rotor tip should be about 20 degrees to the right of vehicle centerline.
5. While watching the points, pull up on the rotor and rotate dist. base until points just begin to open, then tweak back a hair until they just close. At this point the vacuum can should be about half way between the interference points with the manifold an coil bracket, and the window should be close to normal to vehicle centerline. If not, you're a tooth (or more) off, or since the engine is freshly rebuild there remains the possibility that the camshaft is 180 out.
If all is as above, the engine should start and the initial timing should be within a couple of degrees of 10 BTC.
Duke
Old Jul 16, 2005 | 07:13 AM
DansYellow66's Avatar
DansYellow66
Very carefully check your plug wire routing too. Amazing how easy it is to switch a couple wires to the wrong plugs. However, usually it will manage to fire and run - but just barely with a lot of missing and backfiring.
Old Jul 16, 2005 | 01:07 PM
67L36Driver
Set static timing by;
1. Turn crank untill you have balancer mark aligned with desired advance mark on timing tab. Make certain of compression stroke.
2. Install a spare plug wire with spark plug in desired #1 terminal. let the plug lay on intake manifold where you can observe gap.
3. With key switch on, rotate dist housing clockwise well past your #1 terminal. Pop cap to verify and replace cap.
4. Rotate dist housing counter clockwise untill you get a spark at test plug.
5. Repeat 3 & 4 untill you are comfortable of housing position when spark occurs and snug down clamp.
Works on any spark ignition engine. Transistor distributers have to be rotated rather quickly, but it works on them also.
You can also run the timing light while cranking. It takes 3 hands to hold the timing light, turn ignition key and rotate dist housing, so recruit a friend.
To Engine won't start???
