Having added a considerable amount of horsepower (510), I have made as many drive train upgrades as recommended....3 inch half shafts, 3 inch drive shaft, HD flanges, HD U joints, HD yokes and caps. Is their something else that is recommended? This car is NOT a drag strip car but a street car that I may have an occassion to 'hit it' now and again. I don't want to make any structural changes (4 link, 9 inch), rather make the existing drive train as strong as possible. I think a drive shaft loop and half shaft loops may be a bit much but better safe than sorry? I have also added a rear end suspension kit.
There was recently a good article in either Vette or Corvette Fever on making the differential virtually bullet proof. That would be my only other part to add to your list.. Dave.
Depends on what your running for tires and how well they transmit power to the ground. The weak link in your system now will be the rear end, especially the posi window which had a tendency to crack near where the ring gear bolts up. Toms differentials had an article in Hot Rod magazine a few months back which outlines bullett proofing the Corvette rear end. This can get expensive for a street driven car.
My car is a 67, injected 502, 530 hp, 575 ft/lbs torque. I've done all the upgrades like you, I run a stock 3:36 posi and the stock M21 Muncie. The only thing that keeps me from breaking parts at the strip is I run street tires which go up in smoke for the first 60 feet. Best time to date is 12.9, 114 mph. My 2.3 60 ft times hurt over all times, but I drove to the strip and drove home with no breakage. Next time out I will try a set of Drag radials. If something breaks it's time to upgrade.
Good luck with your car.
Russ
Depends on what your running for tires and how well they transmit power to the ground. .......
Russ
I am running Goodrich G-Force KDW's on 20" Torq Thruster II's, I will never take the car to the track. I am running a stock rear end with the same 3.36 gear. I just want to be able to smoke the tires without tearing anything up. Nothing to serious and a rare occassion at that...the tires actually cost more than the rims. Oh yeah....VERY impressive powerplant and times to match.
You're definately on the right track. If you want to improve the 3rd memember get on of Tom's 12-bolt differentials and you'll be good to smoke all the tires you like! You can also ask Tom about other possible modifications...
Damon
Based on the inprovements you've made and the tires your running I don't think you'll have any failures if you drive the car the way you say you will. All this is based on a transmission and rear end that has been serviced and inspected and is in good condition. Have fun and let the rubber fly.
Russ
ps. thanks for the nice comments on my car.
