Big Block Reliability
Randy
We checked oil passages, lobe/lifter bore alignment, you name it, after the first cam went.
The cams that failed were from Comp and Crane. Both were selected on how closely they resembled the OEM 390 hp timing/lift.
I guess if you buy one over the GM parts counter that makes them better.
I've had one BB Chebby but there won't be any more.
I saved all the parts to change the car back to a SB again.
GM made about a bizilloin BB in all sorts of vehicles for a lot of years. If cams went south in most of them, they would have quit long before they did.
Done correctly or alternately left alone they are nearly unbeatable and all this with only one 4 bore carb. Any one that can`t handle a BB, will also screw up any other engine.
This sometimes leads to cam problems.
They often need to be indexed (sleeved).
Aftermarket Big Blocks are more careful with lifter bore alignment.
I have never used it though, so if Mr. Duke is still on this thread I would love to hear an opinion on getting parts cryo treated....
Matt
Who makes them? Where is the .024" hole, in the lifter foot I presume. Centered? Offset?
Normal cam lobe oiling is from crank throw off. A small hole weeping oil directly on the wear point should be an improvement.
Randy
This cam probably has the grooved rear journal. If your block needs a plain rear journal, be sure to modify the rear bearing feed hole per the Chevrolet Power Manual.
Duke
You need to find someone who actually builds racing engines and knows these details.
http://www.primediapowerpages.com/cg...rch/Run/100216
They are from competition products, but other companies sell similar products. The hole is right on the face of the lifter. I think big blocks don't get as much help from the splash oiling that the small blocks do, so I have heard that these are a big help especially for big-uns...
I am keeping my fingers crossed.
Randy
There is some guidance in the Chev. Power Manual, but it does not cover the case of using a non-grooved cam in an early block - just what needs to be done if you use a grooved cam in a later block.
You need to consult with a BB expert like Clem Zahrobsky or Joe Lucia.
Duke
The 1965 and 66 engines are the ones that require the grove in the rear cam journal, without the grove will result in engine failure. As far as the rare lifter bore problem, just be sure not to use a worn out block.
Walt Knoch
..the Mark IV BB has a loooooong and proven history with very little maintenance. 350K+ miles on my last 454 before it's timing chain gave up the ghost. Cam breakin is critical (Moly paste is absolutely necessary for proper seating) as is quality steel.Not to rant off topic, but what's been said above about imported steel goods is true. These days, most steel is poured/cast/manufactured overseas, imorted, then "assembled" in America (so it can proudly wear that "Made in the USA" label
). Often this "assembly" translates into nothing more than adding a small clip, a warning sticker, or reboxing for shipment. Chinese and Korean understanding of metalurgical properties and practices is in it's infancy (< 10 years), compared to the US and more recently Japan. Until costs of production, profit points and our economies find equilibrium, we'll continue to see importation of questionable steel. Likewise, opportunity is always in the margins, so until it becomes cheaper/faster/easier to once again fire up America's foundries & steel plants (highly doubtful), our only defense against junk imports (reproduction parts included) is stricter quality control and/or better educated consumers. The bad news is nobody is exempt; Federal Mogul to FedEx, Costco to Caterpillar - everyone is importing, assembling, wholesaling, distributing or retailing this stuff as a matter of survival. The good news is; taking lessons from Japan, those little guys are fast learners and should have the process down pat within only a few years - popping out top notch products of quality on par with that of the Honda's & Toyota's of the 90's. In the meantime, ask your FLAPS clerks for the Rockwell hardness certificate for every cam, balljoint, tierod and CV joint that passes over that counter
