dash lights
Old Aug 25, 2005 | 08:48 PM
drewdog66vette's Avatar
drewdog66vette
Default dash lights
ok, lights on my dash are not as bright as i would like. sooooo, two questions. can i buy brighter that will fit sockets? also, should i try this with dash in or should i loosen screws to give me some more room. there is one bulb that hangs behind the tach that i cannot find a place for at all. so, how many bulb go to dash anyway. thanks for the help to all on my vent drains. got that licked. you guys all rock.
Old Aug 25, 2005 | 09:05 PM
78Vette-SA's Avatar
78Vette-SA
My suggestion would be to buy a complete bulb kit (Paragon, Long Island Corvette, etc.) or direct from Lectric. They are available over the counter but buying them this way they come with a sheet that tells you what bulb goes where.
Next, it's easier with the front seat out and laying on your back under the dash (see pic). One by one pull the screws out and replace with a 1/4" x 20 steel rod about 6-8" long. Slide cluster out and when you can, unscrew the speedo and tach cables to give you more slack.
Although you can probably now change the bulbs. I would go a step further and remove the console completely (you need to remove the ignition key bezel - turn it to accessory and stick a paper clip in the little hole, it pops off). It's much easier to replace the bulbs in the harness with the cluster out of the way.
My .02. Perhaps someone could suggest some shorter/easier method.
Old Aug 25, 2005 | 10:20 PM
kellsdad's Avatar
kellsdad
Are you getting full bright on the dash light adjustment (rotating the light switch ****)? If the dash lights don't get brighter as you rotate the **** counterclockwise all the way until the overhead light comes on, the rheostat in the headlight switch may be bad. It that is the case, you'll need to replace the headlight switch.
Old Aug 26, 2005 | 02:26 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
As you remove a lamp, replace it. If not, lable each lead and lamp as to where you removed it from. All dash illumination is on the gray wires.
Check each new lamp BEFORE you install it.
Don
Old Aug 26, 2005 | 04:53 PM
67L88Vette's Avatar
67L88Vette
Default Try LED's
I purchased four-point LED's from http://www.whitegauges.net. They're
much brighter, cooler, and wil last longer. They come in various colors
too if you want a tint. You might be able to get the same LED
somewhere else (eBay, Painless Wiring, or Ron Francis wiring). I'm
happy with mine.
John A.
Old Aug 26, 2005 | 08:16 PM
drewdog66vette
Default may try led's
may try the led's. hate being under that dash. i mean hate it. thanks for the tips i will use them. i just have one stinking grey wire light that i cannot find a home for. could it go to radio? i mean i am feeling around and trying to find a hole but no luck. if anyway has that paper that came with lightbulbs i would appreciate it. thanks.
Old Aug 26, 2005 | 08:19 PM
drewdog66vette
Default what size 4 pint did you get
went to that site. what size did you get for dash?
Old Aug 26, 2005 | 09:21 PM
skids's Avatar
skids
I believe their's also a bulb for the cig lighter. Easy to forget. Got that one in?
Old Aug 27, 2005 | 02:05 PM
drewdog66vette
Default yea got that one.
yea, thanks skids got that one in. love the posted pics. to say i am not looking forward to this is an understatement. will prob remove the seat and try it. like the idea about the studs. good one. if anyone has the sheet from those places. i would appreciate a jpeg of it. if possible. dont think it is the reostat? they dim and get brighter, i would just like em even brighter. i am getting old. need to see.
Old Aug 27, 2005 | 07:50 PM
Joemac8's Avatar
Joemac8
Drewdog, let me know how it goes as I have the same problem- age & dim bulb (my dash lights aren't very bright either)
Joe
To dash lights
