I removed the crossmember from the frame but I have not been able remove the bushing from the crossmember, is there a special way or tool I need? Any help would be greatly appreciated. I am trying to get it ready for the powder coating shop next week.
This is what it took to get mine out. You can burn it out with a torch, beat it with a big hammer, or if available, use an Arbor or Hydraulic press. After 40 years mine definately needed some heavy persuausion.
I've restored approx. 20 some mid-years. Everyone I've had the frame and all the suspension pieces powdercoated. I've even had the rear crossmember powdercoated with the bushing in place. Tell the coater not to pre-bake (600-800 deg)the rear crossmember. The bushing will hold up to the 400 deg it takes to melt the powdercoat. I've never lost one yet.
Thanks for the advice but I wanted to replace them now since I have the car all apart. Initial I will just run the motor with the stock setup(500hp) but will boost it to 750hp. So I want everything up to snuff.
I removed mine in my garage with common hand tools.... Hammer and chisel... carefully. Was a real PIA and took a few hours per side. The outer shells of the bushings were "rust-welded" to the crossmember. Not something I'd want to do again. A press would have been nice. New ones went right in.
chuck,
Just take the crossmember to the powdercoater and let him pre-bake the part with the rest of your pieces. This will burn the crossmember bushing out. Then take a wiz wheel or grinder and cut the tabs that are bent over, ( the ones that hold the bushing in) then take chisel and tap the outer sleeve out. If memory serves me right, it will come out in two pieces. I've done two or three like this. The powdercoater forgot what I said and baked a set by mistake. The new bushing will have to be pressed in, a hammer will not do the job. I bought a 20 ton press from harbor freight 8yr ago for $200 and it does the job.
chuck,
cheesecake:
I just tried to reinstall my crossmember which is powdercoated and has the new bushings. The bushings slipped in rather easy but I don't recall any bent tabs when I disassembled them. I really don't want to beat on newly coated parts, is that necessary?
My real problem is the bushings holes don't line up anymore with the frame mounts. Ever see that one?
Yep necessary to secure the bushings into the crossmember. As for them not lining up you may have to take a dremel or such and elongate the holes. The aftermarket bushings sometimes don't line up as nicely as the GM or original crossmember bushings. I found actually that I had to radius the inside of the new bushings that I installed and made sure the sombero's were nice and smooth to facilatate a good smooth engagement. Dave.
OK that's wasn't as bad as I thought it would be, the tabs bent over easily. Just to make sure: the bushings go into the crossmember from the top and the tabs are on the bottom once the CM is installed, right?
I "dremelled" the one hole that was off (driver's side) just a tad and the bolt went right in after that.
I still have a gap between the frame mount and the top of the bushing. Is that normal? I might be able to get a picture if that'll help with the description.
