Need Help-Pulley Problem
Old Sep 10, 2005 | 12:34 PM
1961 fuelcar's Avatar
1961 fuelcar
5th Gear
Default Need Help-Pulley Problem
Getting ready to install the engine back into my car which is a 283/315 hp car. The front water pump pulley and the pulley on the harmonic balancer are slighly rubbing as they turn. Should the pulleys be this close? As far as I can tell everything is the correct part number and everything lines up correctly. Water pump is a 3724816 and the harmonic balancer is a 3756328. All three are deep groove.
