65 396 identification
Old Sep 12, 2005 | 10:57 AM
jrsimm81's Avatar
jrsimm81
Navigator
Default 65 396 identification
i am very interested in a 65 396 coupe i have found the current owner swears it is an original big block but the motor and radiator and shroud are gone. it does have the big block hood and high redlin tach. I have heard of a lot of little clues which dont sound too reliable. have 65s been found with build sheets on them if so where.
the price on the car is a firm 15000 any advice on the price, i am new to vettes car needs total restoration and motor(65 396 l78)
also front end has been mutilated by someone smoothing the headlight doors and istalling headlights in grill, how much would it cost to repair this.
Old Sep 12, 2005 | 11:22 AM
Corbrastang's Avatar
Corbrastang
NO tank build sheet in 65. Look for a rear sway bar and a battery access door in the front drivers side fender skirt, larger diameter springs, and a larger sway bar in the front(not sure what size, maybe someone will chime in here).
Old Sep 12, 2005 | 11:25 AM
Bill J's Avatar
Bill J
should also be a late serial number. Don't remember the 396 start date.
Old Sep 12, 2005 | 11:36 AM
JohnZ's Avatar
JohnZ
Should have:
1. VIN higher than 13,000
2. 7/8" or 15/16" front sway bar.
3. Rear sway bar.
4. Caps and bolts instead of U-bolts on diff yokes.
5. Transistor Ignition.
6. Bag (instead of plastic reservoir) for W/S washers on left inner fender.
7. Cooling system instruction sticker on right inner fender, forward of expansion tank.
These L-78 cars are expensive to restore correctly - there's a June-dated L-78 engine on eBay now ($15K). Putting the headlight area back to stock will be $3K-$5K, plus paint. No build sheets for 65's.
Old Sep 12, 2005 | 11:48 AM
jrsimm81's Avatar
jrsimm81
Navigator
yes i have seen that motor. I will be watching to see if ti sells, he is advertising it as completely correct however the block does not have the correct stamping on the deck which ,after restoring a 69 z28 with a dz 302, is a pretty big deal. might just be sticker shock on my part
Old Sep 13, 2005 | 03:33 PM
Corbrastang
let us know what you find out.
To 65 396 identification
