C2 tach -- Mechanical Engineer's perspective?
It would be nice to hear a Mechanical Engineer's view of this.
From what I see, the tach driven gear has a thrust washer on the side that mates to the brass bushing screwed into the distributor housing -- but, that is not the side of the gear that takes the thrust. The nose of the driven gear is pushed into the housing of the distributor by the rotation of the distributor. On my car, this eventually caused the driven gear to "lock up" and destroy both the driven gear and the distributor shaft/gear. I'm told this is a common occurrance.
It seems to me the thrust should be applied to the side with the thrust washer. Was this just a mistake by the people that designed it, or is there a logical reason (that I am missing) for this design?
Tom Piper
My original dist with well over 200,000 was still in fine condition when I finally "overhauled" it. Actually just cleaned throughly and regreased/reassembled it with the small parts kit.
Another I got at a swap meet had a stripped cross gear and a deep pit eaten into the housing. No telling how many miles it had on it but it was short on lubricant for sure. I rescued the housing with a 5/16-24 set screw and jam nut and using it untill I get my Trans Ignition sorted out.
The distributor should be disassembled, cleaned, and relubricated at least every ten years, regardless of mileage, but my bet is that many have NEVER had this simple service.
Duke
