Dampner Movement
Old Sep 20, 2005 | 10:28 PM
ghostrider20's Avatar
ghostrider20
Default Dampner Movement
One of my buddies stopped over tonight, and when timing the car, I noticed the balancer thrusting forward about 1/8"-1/4" when the motor was revved. Returned back when the RPM decreased.
Is that normal, I guess I never noticed it before on anything else.
Mark
Old Sep 20, 2005 | 11:00 PM
jerrybramlett's Avatar
jerrybramlett
Default No
I believe the crank thrust should be to the rear and too small to notice.
Old Sep 20, 2005 | 11:05 PM
ghostrider20
That's what I thought, to the rear, so what would make it thrust forward???
Mark
Old Sep 20, 2005 | 11:09 PM
67L36Driver's Avatar
67L36Driver
Default Not Normal.
Crankshaft end play should be .003"-.011" .
Old Sep 21, 2005 | 08:16 AM
MikeM's Avatar
MikeM
Mark
Sounds like your buddy's engine is about to go on a weight diet. Is the whole damper moving forward or just the outer ring?
Old Sep 21, 2005 | 10:35 AM
muncieman's Avatar
muncieman
Default Good question
Mark
I've seen torque converters cause this problem but you need to make sure the outer ring on the damper is not moving.
Put a pry bar behind the damper and pull or push it and see if that makes it move more than the normal amount, .003 to like .012. If it moves load the thrust on the crank or the thust bearing or both has checked out and it's time to pull the motor and repair the problem
Old Sep 21, 2005 | 11:57 AM
67L36Driver
That much endplay indicates the bottom end is shot. Next, you will start to hear clicking at idle. The big end of the rods will start hitting things.
Old Sep 21, 2005 | 12:43 PM
Scott Marzahl's Avatar
Scott Marzahl
Default Dampner
It isn't all that uncommon for the outer dampner ring to come off and do some serious damage underhood. Some engine builders drill and countersink three bolts in a new dampner at 120 degree intervals to prevent it from coming apart at high revs.
Old Sep 21, 2005 | 12:58 PM
muncieman's Avatar
muncieman
I've seen that done, wonder what affect that has on the ability of the dampner to do it's advertised job??
Old Sep 21, 2005 | 02:10 PM
Scott Marzahl
Default Dampner
The dampner on my 383 that I ran with NOS had that done and there were never any problems. I used the Chevy 8" modular iron dampner with the bolts not torqued down, just snugged with nylocs nuts.
Old Sep 21, 2005 | 02:24 PM
henny496's Avatar
henny496
Default dampener
Hello
I would replace the dampener. Not only will you get false readings for the timing on one that has the outer ring slip, but it can come apart.
This is why you drag cars replace them, for the same reason you replace bellhousings and cast flywheels
take care
Tom
Old Sep 21, 2005 | 02:41 PM
babbah's Avatar
babbah
Replace the stock damper with the Fluidampr and you will never have to worry about a outer ring problem again.
Old Sep 21, 2005 | 03:07 PM
ghostrider20
The whole dampner is moving. You can noticably see it thrusting forward with revs. I doubt you would notive .003-.011 movement.
Motor sounds good, runs good.
Mark
Old Sep 21, 2005 | 08:08 PM
MikeM's Avatar
MikeM
Default Ya' better pull it 'fore it flys apart.
Mark
Old Sep 22, 2005 | 09:24 AM
ro.co3's Avatar
ro.co3
I'm assuming your running a small block and most likely the balancer is not bolted but pressed on. I had one come off awhile back doing 70mph,
lucky me no damage. Anyway pull the belts and and inspect the balancer if it moves replace it and by all means drill, tap and bolt it on. I did and have had no problems since. If you do a search on this you should find allot of info. good luck.
Old Sep 22, 2005 | 09:37 AM
ctjackster's Avatar
ctjackster
"whole dampner is moving" means it is migrating out along the snout.
give it the SHP treatment and drill / tap for a bolt, such bolts are available since they were done for the SHPs. Discussion Threads exist on doing this with engine in car, rad removed. Center punch already exists in snout.
here ya go, parts and pictures:
http://forums.corvetteforum.com/show...um_id=4&arch=1
would seem that Mark - Coves4me did this and might be able to offer some advice
Old Sep 22, 2005 | 10:00 AM
Tom Piper's Avatar
Tom Piper
Sounds like the "thrust" flanges on the thrust main bearing are worn.
I saw one like this, it was caused by the clutch being held in too long and too often -- wore the thrust bearing out.
Tom Piper
To Dampner Movement
Old Sep 23, 2005 | 04:00 PM
Tom454's Avatar
Tom454
Tom Piper
Unless the damper is loose on the crank... and is just following the belt tension as RPM changes. Grab hold of the damper & wiggle it... if it's worn bad enough to move in & out when spinning, then it will probably wiggle when it's not running. Otherwise, I'd go with the thrust bearing theory... which you can easily check by putting the tranny in neutral and forcing the crank forward/rearward (engine off).
Didn't catch which engine you have.... but the early 327's had press-on dampers and un-threaded crank snouts. I think Fluidampers require a threaded snout.
Old Sep 23, 2005 | 05:26 PM
FXT
Guest
Posts: n/a
Reading this thread reminded me of the same thing concerning my '67 L-79 small block harmonic balancer. Ordered the correct new one #3817173 yesterday from http://www.gmpartsdirect.com/ .It cost $76.oo + S&H. I'm not going to flirt with disaster. Here is intersting article on balancers.....http://www.chevyhiperformance.com/techarticles/4402/
Old Sep 24, 2005 | 09:00 PM
JohnZ's Avatar
JohnZ
Good article on what "balancers" (dampers) really do, but I'm continually amazed at all the recent articles that say the pre-'69 timing index line is offset 2* from the keyway centerline. I guess they just copied what the other magazines said, and never bothered to look at the GM damper drawings to get the correct information; the index line is dead-centered on the keyway slot and pulley bolt hole center, +/- 1/4 of a degree tolerance.
