Alternator Belt Alignment
Old Sep 24, 2005 | 11:57 PM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
Default Alternator Belt Alignment
I opened the hood today to check all fluids etc etc. I noticed that my alt belt is showing signs of wear towards the water pump side of the belt. I am thinking alt needs to go out more away from the water pump to correct this problem. My question is whats the best way to tell if pulleys are lined up properly.(I can't tell by eye) My first thought was some sort of straight edge. I have aftermarket zoops brackets, pulleys etc, so i should have some adjustment. Thanks Sixty4.
Old Sep 25, 2005 | 08:19 AM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
sixty4,
You're on the right track. I just went through this (blowing water pumps and as a result tracing the first water pump failure to a combination of belts too tight as well as pulley's just not aligned up. Use a straight edge to determine how close your alignment is.
If your pulley setup is not using factory stock pulleys, then your alternative is to purchase shims for the water pump pulley (they fit behind the pulley, undetectable, and could help with your alignment. If you are running stock pulleys you should have no issues on alignment.
Also, if you can find a shop that rebuilds alternators in your area, they may have a thicker/thinner pulley for the alternator that would accomplish what you need. The key is to carefully measure what you need, usually a 1/16" or possibly 1/8".
Good luck
JIm
Old Sep 25, 2005 | 09:05 AM
Ron Miller's Avatar
Ron Miller
Originally Posted by 6T5RUSH
sixty4,
JIm
If you find it difficult to get the proper length straight edge between the two pulleys, use a piece of string stretched between the two. Use the two front flanges of one pulley, position the string until it is just touching the front of each flange, and "shoot the line" across to the next pulley. Lots of times its much quicker & easier than a straight edge, sometimes the straight edge works better!!
Old Sep 25, 2005 | 09:26 AM
78Vette-SA's Avatar
78Vette-SA
MOR-64035 $6.95
Estimated Ship Date: Tomorrow
Application Show All
Brand: Moroso
Product Line: Moroso Universal Water Pump Pulley Shim Kit
Water Pump Pulley Shim Material: Aluminum
Shim Center Hole Inside Diameter (in): 0.750
Quantity: Sold as a set of 3.
From www.summitracing.com
Used them many times.
Old Sep 25, 2005 | 11:54 AM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
Thanks to all for your advice - I think I have a resolution to the problem. Joe - thanks for the info on shims, as shims will probably solve the problem, but not water pump shims. I'll need to go with alternator shims, as it's the alternator that's out of alignment. Simpler fix than I originally thought.
Thanks again to all for your input....
--sixty4
Old Sep 25, 2005 | 02:53 PM
Seaside63's Avatar
Seaside63
You might have the wrong pulley on your alternator.
On my 63, the correct pulley is a machined steel item that is thicker on the back than the incorrect stamped steel pulley I currently have. I will have to replace the pulley before the car goes back together.
To Alternator Belt Alignment
