Piston Options
P.S. Car is a garage queen!
There were two 327s in '67. Do you still have an original engine or a replacement?
Are you looking for a stock rebuild? Blueprint rebuild with a little more omph or something entirely different?
Duke
If you're an idler rather than a burnout guy, forget the forged pistons. Keep the L-79 stock cam and the domed pistons high compression. You'll never know the difference if you do get weak and do a burnout. Why would you want to hone your cylinders out bigger?
This time I changed out those .030 over forged pistons for .040 over KB flat top hyperutectics. The cylinders didn't need much finish honing to bring them up to .0015 piston-to-wall clearance which is what the manufacturer recommendeds for a street driven engine using this type of piston. This time I checked it .! . .
.. IMO, unless you plan on using nitrous or really hammering on the engine hard hyperutectic pistons are the way to go for a street driven engine. It's said they run quieter and seal better with less ring rock compared to the forged type. In the KB line hyperutectic pop-up style pistons are available. I decided to go with flat top hyperutectic pistons mainly for 3 reasons. 1) The 91 PON premium here in CA. ........ 2) I plan to drive my car a lot (touring, etc.) and don't want to bump up against the detonation envelope, should it come to that ....... 3) My hearing ain't the greatest these days . . . .
.. Would I even hear it .! . Outside of reworking the heads (new valves, springs, etc.) and doing some 'backyard' porting on them this engine has the LT-1 cam. SCAT connecting rods replaced the stock units and the rotating assembly was balanced. With a frame-on resto project in the works my engine is still, well, on the engine stand!.
John
There has been much discussion about rebuilding engines, especially in regards to establishing a target CR for the application and installed cam and then achieving it. First you plan, then you measure, beginning with engine teardown.
Time to search the archives.
Duke
They are a satisfactory choice for replacement (especially for conventional cast OE pistons), however, if you are sticking with L-79 specs I would use the OE replacement forged pistons and target a CR of 10.5:1 as I previously stated.
It would help if you would provide more information about the condition of the engine. Is it disassembled? Did you measure deck clearance on all 8 prior to disassembly? What is the measured bore size, and how much taper and out of round is measured?
Being as how it's already been bored .030", I don't understand why it needs to be rebuilt again.
Duke
..JohnI went with the hyper speed pro w.125 dome.
Gary
Most 'aluminum' castings are Al-Si alloys. The maximum amount of Si miscible in Al is about 12.5%. That composition is the LOWEST melting point of any Al-Si alloy (~1070F) & is referred to as the 'eutectic' composition. An aluminum alloy with <12.5% Si is called HYPOeutectic; one with >12.5% is HYPEReutectic. Since the HYPEReutectic casting cannot retain all the Si in solution upon solidification, special techniques & equipment are required to ensure that the Si that is precipated is finely & uniformly dispersed in the piston.
To expand somewhat on your question; most 'aluminum' castings are Al-Si alloys. The maximum amount of Si miscible in Al is ~12.5%. That composition is also the LOWEST melting point of any Al-Si alloy (~1070F) & is referred to as the 'EUTECTIC' composition. It follows that an aluminum alloy with <12.5% Si is called HYPOeutectic -- your intake manifold & 'traditional' cast pistons fall in this category; one with >12.5% is HYPEReutectic. Since the HYPEReutectic alloy casting cannot retain all the Si in solution upon solidification, special techniques & equipment are required to ensure that the Si that is precipated is finely & uniformly dispersed in the piston to achieve high strength and decent ductility.
A forged piston, on the other hand, is made from a solid slug of an appropriate aluminum alloy (probably HYPO) that is heated & forced into die to achieve its rough net size/shape. Thus, there's more of a flowing 'grain' structure in the forged piston when compared to the 'crystalline' structure of a cast piston. They can take more punishment than a typical cast piston due to their structure, but may be heavier & perhaps more noisy than a high quality HYPEReutectic.
I am not sure, but would expect that the OEM flat-tops were cast (HYPOeutectic) & the domed hi-perf engine pistons were forged.
P.S. Duke, your local library historical director gave me the name of that ship carcass on the Redondo Beach. PPS. Suggestions for places to buy pistons?BTW, .030 = what C.I.?
Proper results require a plan! Does bore wear dictate overboring?
The reason for measuring deck clearance prior to disassembly is to determine the deck height relative to OE nominal and have a dimension you need to compute CR. It will also tell you if your decks are parallel to the crankshaft axis. Usually they are and usually one is a few thou higher than the other. If the LH side is higher it can be cut down to the RH height. Of course, you DO NOT want to touch the RH deck or you'll destroy the numbers. Machine shops often do this contrary to specific instructions. Caveat Emptor - make sure your instructions are WRITTEN!
Shops should have tools to measure actual deck to c/s axis distance. The nominal blueprint dimension is 9.025", but most production blocks are high - typically by about .010 -.020", which is about half-a-point of compression.
Deck clearance/deck height combined with piston compression height, rod center to center length, piston dome or dish volume, head chamber volume, and gasket thickness allow you to compute CR to achieve your target.
Pistons must be evaluated and selected PRIOR to any machine work, then the engine bored and honed to proper fit for each piston using the proper final stone to achieve the specified finish for the type of ring face selected, which is usually moly face for street engines (OE was chrome.) ALWAYS follow the piston manufacturer's recommended clearance to the LETTER for the specific piston used.
Like I said, there is much discussion about the topic of engine overhaul planning in the archives - and many posts on the subject under my screen name, including a link to a good online CR calculator.
Duke
If you have any other questions, E-mail me
Charlief
66 Coupe
Also, much discussion in the archives about the weak, early 327 rods. Your '67 vintage rods are better, but I hope you at least have them Magnaflux inspected to be sure none are cracked.
With the OE domed, forged pistons, typical OE machined deck clearance, and a typical thick composition head gasket, true CR will be not more than 10.5:1, and the engine will operate detonation free on unleaded premium with no more than a little initial timing diddling.
If true CR is about 9.6 the engine should operate on midgrade. The late LT-1s had a specfied CR of 9.0:1 (actual was probably closer to 8.5) and they were DESIGNED to operate on regular unleaded - 91 RON, which is equivalent to today's 87 PON.
Duke
