headlight motor limit switch
Old Oct 8, 2005 | 11:52 AM
eyedocs96's Avatar
eyedocs96
Default headlight motor limit switch
I'm sorting out some wiring problems on my 65 corvette. The limiting switch has "common" on one terminal and "norm. closed, norm. open" on the other terminal. I'm not sure which one is the ground or which is the power side to the switch. My wiring diagram doesn't tell me where the black and gray/black wires go.
Thanks Brian
Old Oct 8, 2005 | 12:18 PM
Geek's 65's Avatar
Geek's 65
Brian,
Are you talking about the headlight warning switches? The actual limit switch is in the motor.
Old Oct 8, 2005 | 12:35 PM
Ron Miller's Avatar
Ron Miller
Thanks Brian
Doesn't really matter, they'll work either way. The switch as used on the Corvette is constructed internally to be normally closed. The same switch can be constructed internally to be a normally open switch by the manufacturer when used in other applications, thus the "norm. closed, norm. open" labelling.
On the Corvette application, I believe it only furnishes a ground for the circuit to operate, so connecting the wires as is shown by the wiring diagram, or reversing these two connections makes no difference in operation of the circuit.
Old Oct 8, 2005 | 02:34 PM
Hitch's Avatar
Hitch
That switch as stated above is not a limit switch only a tell tale light for the dash indicator. It doesn't matter which connector you connect to either side of that switch. Both of mine were not even connected when I bought the car and the headlights worked fine. The headlights are limited in travel by the "Y" stop on the inboard side of the headlight bucket shaft.. Dave..
Old Oct 8, 2005 | 02:54 PM
Ron Miller's Avatar
Ron Miller
That's true as well, the limit switch is not in the headlight bucket motor circuit, it's in the warning light circuit which feeds power to the "lights" warning light in your instrument cluster.
To headlight motor limit switch
