Thanks Stepinwolf!
"Had an adventure today. Anytime you drive a C2 coupe in 95+ degree weather it is an adventure.
Today's surprise was the drivers vent window. I opened it and noticed that it protruded back from the frame. I grasped the window and voila, it came out in my hand. It appears to be completely intact.
Is there some adhesive to use to "glue" it back in place? If not, how is it retained in the frame? I would surely hate to loose an original window."
Stepinwolf stepped up to the plate and told me about window tape and how to install it. He also said that If I couldn't find any, he would send me some for a very nominal price as he bought a roll some years ago. For less than $10 I got enough tape to do all of my windows.
Well, it took a while but I did the job as instructed by Stepinwolf and it turned out great.
Once again, this forum and Stepinwolf came through to help fix another C2.
Thanks Stepinwolf!
He knew I'm planning to install an A/C in my '65 this winter and having done it numerous times before he also knew of where I would run into a problem on the install.
Next thing I know I get a package from Canada with one of his custom built brackets to solve this installation issue he knows I'll run into.
Stepinwolf
Drive your Corvettes
as if each day was your last
