Header side pipe repair question????
Old Nov 6, 2005 | 08:53 PM
iniguy's Avatar
iniguy
Default Header side pipe repair question????
I have a set of stal header side pipes that have finally rusted through in the collector web area where the 4- 2 1/4 primary tubes come together.
Has anyone had any luck trying to fix them?
They've been on my car since 1968 and fit much better than Hooker or Doug Thorley. I really want to keep them.
Thanks!
Old Nov 6, 2005 | 09:01 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I think you got your money's worth. Joking aside, if it rusted through there I'm sure trying to patch weld or whatever technology is used will be a waist of time and money. The surrounding area is probably ready to go. Check her on the forum search since many guys have headers into sidepipes, including myself, and you will find the right make and model for replacement. Mine are Hedman into factory sidepipes, but are only 11-12 years old. Get new ones with the Jet Hot coating, they look great and last many years. Dennis
Old Nov 6, 2005 | 09:49 PM
65convt's Avatar
65convt
Stahl is still in business. I believe he is only building custom applications now but you could check.
\ I have the Hedman BB side exhaust Headers ceramic coated inside and out. Used Hedmans on my Mid year 30 years ago. They make a good header.
Check Summit.
Old Nov 8, 2005 | 05:45 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
If the metal is still workable you can slice the old collectors off and put new ones on. No big deal. Stahl will sell you new ones.
Pops
To Header side pipe repair question????
