Shocking
Old Nov 16, 2005 | 06:00 PM
Norman Teegardin's Avatar
Norman Teegardin
Default Shocking
Sometimes when I honk my horn on my '61 vette, I get shocked. What is the problem?
Thanks, Norm
Old Nov 16, 2005 | 06:34 PM
NVaVettes's Avatar
NVaVettes
I'm 'cause mine zaps me too!
Hummmm..... I've got leather seats....would vinyl act as an insulater?
Old Nov 16, 2005 | 06:59 PM
K2's Avatar
K2
Electricity takes the easiest path to ground. You must be a well grounded individual! Or else your steering column / horn button ground isn't.
Old Nov 17, 2005 | 12:14 PM
JohnZ's Avatar
JohnZ
Thanks, Norm
The horn button's path to ground is through the upper steering shaft bearing to the shaft; if contact isn't good between the I.D. of the bearing and the O.D. of the shaft, it'll ground through you instead.
To Shocking
