I am going to rebuild my factory 327 for my 65 as a side project.. this will be my first engine rebuild, but have done things far more complicated I believe.
I am looking for a GREAT engine rebuild book that will go step by step on what to do from teardown to rebuild. I also would like a book that talks about torq specs on my 327 and any other useful information.
In addition, this motor may sit for quite a while.. Is there a way to store it so that if 5 years down the road I could just throw it in the car? Or is it simply better to just wait till I want to put it in, and rebuild it then? Thanks..
I'd go to Amazon.com and search small block chevy. I just did and came up with a half dozen good books. I have several of them and have gotten lots of good info from all.
You will undoubtedly get a lot of responses from different Forum members, with each one recommending their preferred book.
As for myself, I actually have EVERY Chevy " How To " book ever published, along with a few out of print. The best one I have found for a beginning engine builder is the rebuild book by Larry Atherton & Larry Schreib. It is the latest revised edition of " How to rebuild the SMALL-BLOCK CHEVROLET ".
It takes you by the hand, and with more then 650 numbered photos, showing you exactly everything you must do to dis-assemble, and rebuild your engine. Covers all the Chevy small blocks, including the 327.
Check the " Amazon " web-site for pricing, and also to check out a few pages of the book.
The latest edition also includes a 2-hour DVD that includes all the basics, plus the machine-shop processes.
I've built them and had them sit for up to 18 months or so - I just oil up the cylinders, back off all the rockers, tape over all the ports, and store on the stand with a cloth cover (don't seal it up in a bag - that will trap moisture and rust things). At install time, re-adjust the valves, prime the oil system, and let it rip; don't turn it over while it's in storage - you'll wipe the assembly lube off the cam lobes, and you need that when you first-fire it to break in the cam.
John,
Look's as though I got the crap end of the stick, because I purchased it when the new revision first became available, and no DVD was included in the deal. So I guess we win some, and loose some.
Surprised no-one's mentioned my countryman, David Vizard.
How to rebuild the Chevy Small Block.
Also, his how to build maximum horsepower on a budget book is pretty flippin' good reading too. I have a book he wrote before he shipped out about cylinder head modification. Man's a phenomenon.
I found David Vizards book to be really useful. Another great tool is this DVD from Eastwood Co. http://www.eastwood.com/shopping/pro...ord=dvd+engine
This DVD has a great amount of detail. i would be confident that even a first timer could rebuild an engine perfectly with this weapon in the arsenal. IMHO i think it is better to do your own engine work. Why trust Bubba at the machine shop to assemble your engine. Last time i trusted Bubba he took the numbers off my numbers matching block.
