E-Brake Instrumental Panel Light Switch
Old Nov 28, 2005 | 08:04 PM
vaughn_logan's Avatar
vaughn_logan
Default E-Brake Instrumental Panel Light Switch
Hello All:
I am trying to locate a switch, that evidently fits on my emergency brake assembly, which illuminates the "brake light" on my instrument panel when pulled.
I have the wiring harness extension leads ... but it requires the switch as well.
I have tried the usual places (Corvette Central, Ecklers, etc.) but to no avail.
This is for a 1960 Corvette !!!
Thoughts Anyone?
~Vaughn Logan~
Old Nov 28, 2005 | 09:46 PM
62fuelie's Avatar
62fuelie
Originally Posted by vaughn_logan
Hello All:
Thoughts Anyone?
~Vaughn Logan~
These are not reproduced and are a bit hard to come by. Mary Jo Rhoner in Ca. will likely have one. Hang on to your wallet with both hands. Also, if you are a NCRS member, the Driveline will ocassionally list one.
Old Nov 28, 2005 | 10:41 PM
splidecision63's Avatar
splidecision63
I have a 59 and my switch went bad also. I thought about going to the local NAPA dealer or Auto Zone. They still carry some parts for our cars. Most people don't think about the local parts dealers. If they don't have one they can probably get one. I'll check and let you know. If you find one B4 I do, please let me know.
I'll try and go by NAPA on wednesday.
Thanks George
Old Nov 28, 2005 | 11:56 PM
vaughn_logan
Thank You George ... but I'm afraid that I am already knee deep in it.
Please see my other post regarding "1960 Corvette Emergency Brake Switch With Flasher Unit".
I think that I just purchased the farm for around $300 for this e-brake switch and flasher. DooooOOOOOHHHHHH !!!
~V~
Old Nov 29, 2005 | 09:36 PM
splidecision63
Hello Vaughn,
As I mentioned I am working on my e brake switch also. When I took mine out, there wasn't any flasher wired in. Is the flasher wired in the switch or is it a serarate component? I am going by NAPA tomorrow to see if they can get me one.
George
Old Nov 29, 2005 | 11:20 PM
62fuelie's Avatar
62fuelie
Originally Posted by geo1rem
Hello Vaughn,
George
Unfortunately, you won't find a switch at NAPA. This is not to say that with some imagination a generic switch might not be rigged up. The flasher is a separate unit on older cars, but the 61-62's used a flashing bulb which is easier to wire,
Old Nov 30, 2005 | 09:12 PM
splidecision63
U R right NAPA does not have one. I am going to call keen.com tomorrow. Looking on their web site, doesn't show one, but they may have one not identified.
Why do we need one that flashes? To be original? I would like to haave one that works. Any ideas on where I can find one?
George
Old Dec 2, 2005 | 09:43 PM
62fuelie's Avatar
62fuelie
George
You can probably get one from Mary Jo Rhoner, or possibly Paragon or Chicago Corvette. Just like a heater switch, it will be expensive. You might ocassionally find one on ebay or in NCRS Driveline.
The original flashed, but it isn't necessary unless you just want to be correct. Flashing is easily done by using a 61-62 style bulb.
To E-Brake Instrumental Panel Light Switch
