OK, I promissed I would replace the rubber fuel line, so I'm looking for braided line. Local parts stores do not carry this type of fuel line. So, Summit or Jegs AND any recommendations (pics would be great)
I am surprised the auto parts store does not carry it?
Anyway, at the auto parts store here it is sold by the foot, and is spendy.
The "kits" are an azz pain, just buy the roll of rubber core, steel braided shield exterior.
PS. This stuff is hard to cut, a side cutter will not cut it, snips, pipe cutter. If you try and cut it with a hack saw, the ends will get frayed and burred.
I take large electrical shrink wrap, cut it in 1 inch lengths, slide it over the area I want to cut, and heat it up. (You can use electrical tape also). Next I take my air driven angle grinder with a thin cutting disc on it to cut the hose. Makes a pretty clean cut, and I leave the 1/2" of shrink wrap on the end.
The fuel line is under fairley low pressure - @ 9psi I believe.
If your line is clamped properly and the rubber hose is new and not rubbing against metal on a consistent basis - then what exactley is the advantage of a ss hose?
Use regular steel tubing. Buy/borrow a bender. FLAPS sells it in different lengths. Also possible to use two short lengths with a union. Makes for a far more professional job, not to mention much safer. Rubber hose is for the suction side of the fuel pump.
Use a length of welding rod or coathanger to mock up the line and plan your bends.
I agree. Hard lines [steel or aluminum] should be used for pressure side. I have used 3/8 brake line for this application. Worked very well.
Don
I personally don't even like the braided lines... Lars has a good article in one of the tech sections outlining an easy way to make a hard line to include a filter... Dave..
Go to the nearest commuter airport, and find the parts shop, the usually carry all types. Also look on the yellow pages for a local hydraulic distributor, one of them should carry the Aero Quip line, they have all you will need. Stay away from the Summit or Jegs brand they are junk
