Need help with engine
Old Dec 19, 2005 | 12:42 PM
Mike'sincorrect66's Avatar
Mike'sincorrect66
Default Need help with engine
I am having trouble with my 327 in my '66. It has a "flat spot" when I step on the accelerator. I took it to the Carb Shop in Denver, and after they re-jetted and adjusted, and dyno-ed it, it came back with the same problem. They offered to take another look at it when it warms up around here, but I was wondering if anybody has any ideas before I bring it back in. Is anyone familiar with this type of problem? What usually causes it? Is it the Carb or maybe something else? I'm getting to the point of real frustration with this.
Old Dec 19, 2005 | 01:40 PM
67L36Driver's Avatar
67L36Driver
Heat riser valve operational? Without it, you will have a bog in cold weather.
Old Dec 19, 2005 | 05:27 PM
stingrayl76's Avatar
stingrayl76
Default Ignition may be the problem
Mike,
Go through the ignition system and make sure timing and dwell are set to spec. Also, check the centrifugal advance to see if it is operating properly and that you have the correct vacuum advance canister connected to manifold vacuum.
Old Dec 19, 2005 | 06:49 PM
SPLITRAY's Avatar
SPLITRAY
You said they re-jetted and adjusted...no rebuild????
If that's the case....your problem sounds like a typical accelerator pump gone bad.
r/ Mike
Old Dec 19, 2005 | 09:26 PM
don peters's Avatar
don peters
Veteran: Coast Guard
r/ Mike
Would be fastest and easiest to check also.
Don
Old Dec 20, 2005 | 10:08 AM
Mike'sincorrect66
Thanks guys, I'll let you know how it turns out.
Mike
Old Dec 20, 2005 | 12:11 PM
Allcoupedup's Avatar
Allcoupedup
Originally Posted by stingrayl76
Mike,
Make sure the entire timing CURVE is correct before contacting the carb guys. Your advance might not be coming in until late in the RPM band.
brian
Old Dec 20, 2005 | 12:53 PM
JohnZ's Avatar
JohnZ
A "flat spot" (or hesitation, or "bog") is almost always a temporary lean condition during the transition from the idle system to the main metering system; this is supposed to be covered by the accelerator pump shot. Make sure the pump adjustment is correct (properly set at the WOT linkage position, not at the idle position), you have the proper pump cam installed, the proper shooter, the check ball installed under the shooter, and the pump diaphragm isn't ruptured.
To Need help with engine
