Replacement Battery
Old Dec 31, 2005 | 10:00 AM
dmentzer's Avatar
dmentzer
Default Replacement Battery
I am in the process of rebuilding my engine and since I have everything out of my engine compartment I fell it might be convenient to replace my battery. Any good recommendations on a replacement battery. Not looking to be judged, just want a good long lasting battery.
Old Dec 31, 2005 | 10:13 AM
copterbc's Avatar
copterbc
I highly recommend the Optima (red top) battery. It is long lasting, warns you when it getting weak, and never needs fluid since it is a dry cell. It has lots of cranking power, works well in cold weather and isn't bothered by very hot weather either.
Old Dec 31, 2005 | 10:24 AM
Donald #31176's Avatar
Donald #31176
If judging is not an issue, I would go with the minimum cold cranking amp battery necessary for your car. There are only a couple of manufactors that make batteries for the country. I use a Costco battery made by Johnson Controls rated at 575 CCA. Been in my C-1 for 5 years and cost at the time $29.95.
Old Dec 31, 2005 | 10:37 AM
SWCDuke's Avatar
SWCDuke
Any Group 24, which is the proper size. The Costco, Pep Boys, and Autozone house brands are all made by Johnson Controls and are good for five to eight years if kept charged and not allowed to severely discharge.
Peel off the labels and you have a plain black, unobtrusive looking battery for about 40 bucks.
Duke
kidvette's Avatar
kidvette
Got to go with the Optima! Really useful if you do lots of maintenance on your car and it requires lots of cranking.
Old Dec 31, 2005 | 02:09 PM
Seaside63's Avatar
Seaside63
Does anyone know who makes the new AC/Delco batteries? Are they even made in the USA?
It must be 10 or 20 years ago when GM closed the Delco battery factory in L.A.
I just bought a new Delco battery from Pep Boys for my daughter's Oldsmobile. It was $69. Works great.
Old Dec 31, 2005 | 02:26 PM
SWCDuke's Avatar
SWCDuke
AFAIK GM still manufactures Delco batteries in house and only manufactures "Delco" brand batteries, but it's been awhile since I've heard anything new on this front. They've never manufactured batteries for any other brand names.
The only other car battery manufacturers in North Amercia are Johnson Contols and Exide including the Exide-Yuasa joint venture. Johnson Controls does not offer batteries under their corporate name, however, they manufacture Optima batteries, which is a brand they own, and they manufacture most of the brand names you will run across in parts stores for customers who own those brand names.
Exide manufactures under their own name, subbrands, and also for other brands.
The clue as to whether a common lead acid battery was manufactured by Johnson Controls or Exide is the difference in case design details. Within the brands that each manufactures, the only real difference is the stick-on labels. And AFAIK the only difference between different warranty periods - 60, 72, 84 months,...whatever - is the price. A longer warranty period is essentially just a priced in "service contract", and you are usually better off buying the least expensive, lowest warranty period battery in the size group, especially if you understand how to maintain a battery to achieve maximum life.
If you want to "get smart" on automotive batteries, do some surfing on the following two sites.
www.johnsoncontrols.com
www.exide.com
Duke
Old Dec 31, 2005 | 02:49 PM
Kensmith's Avatar
Kensmith
I have had both of the Optima batteries and prefer the yellow top. They are excellent batteries. But in your Corvette, I think I would want a black battery as the Optima sticks out like a sore thumb.
Old Dec 31, 2005 | 03:19 PM
Seaside63's Avatar
Seaside63
Thanks Duke !
Old Dec 31, 2005 | 05:30 PM
Grey Ghost's Avatar
Grey Ghost
I've heard the advantage with the Optima are the individual cells with smaller plates vs. large plate in a regular battery. Great for high vibration and harsher environments. Not convinced they are worth the extra money for our usage.
Old Dec 31, 2005 | 05:45 PM
SWCDuke's Avatar
SWCDuke
[QUOTE=Grey Ghost]I've heard... QUOTE]
If you want to understand the differences between Optimas and conventional lead acid batteries, look at the Johnson Controls web site.
Duke
Old Dec 31, 2005 | 07:27 PM
ctjackster's Avatar
ctjackster
I have known for some time about the desireability of a Johnson Controls made battery; when Sears stopped using JC for their Die Hard brand the quality and performance suffered immediately.
I must say, however, that I have had no problem, ever, with an Optima battery - have 2 of them in my boat, 2 of them in my Avalanche, and one in my 65. HAving had the joy of batteries crapping out (who hasn't) in boats and cars, I put good batteries in the same category as tires - don't care if they don't look period correct, I just want them to work well.
To Replacement Battery
