compression test on my BB
Old Aug 4, 2001 | 03:18 PM
jeff batchelor's Avatar
jeff batchelor
Default compression test on my BB
I did a compression test on my car today,and 7 cylinders were between 175-200 psi. One cylinder was 65psi. I added a couple of squirts of oil and it only came up to 75psi. What do you think, cracked rings mabe? Car is smoking on that side. thanks Jeff
Old Aug 4, 2001 | 07:07 PM
pittsaj's Avatar
pittsaj
Default Re: compression test on my BB (jeff batchelor)
Next you need to do a leakdown test to see what's leaking..
Could be a valve, indicated by air leaking through the carb or the exhaust..
If air leaks out the oil filler it's a ring.
Good luck
Tony
