ground straps
Old Jan 9, 2006 | 10:59 AM
panchop's Avatar
panchop
Default ground straps
I'm chasing an electrical gremlin. i can't find a single ground strap other then the one on the motor. my manuals don't show all the straps. anyone have a list of where they should be.
Old Jan 9, 2006 | 11:17 AM
BarryK's Avatar
BarryK
1. RH engine mount to block
2. LH body bracket
3. antenna ground strap
4. accelerator lever to intake manifold bolt
5. one or two (can't remember) from the undercar exhaust hanger(s) if it's NOT a side exhaust car.
Old Jan 9, 2006 | 05:32 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Look in the U69 radio section in the back of your AIM. It'll show you.
In addition to Barry's list, I would add that there should be straps on the muffler mounts too, in addition to the two straps up by the trans crossmember where the front pipe meets the rear pipe. Chuck
Old Jan 9, 2006 | 09:49 PM
1KULC7's Avatar
1KULC7
Veteran: Coast Guard
Look in the LIC catalog...think they list it...
Old Jan 10, 2006 | 10:50 AM
panchop's Avatar
panchop
2. LH body bracket
thanks guys, the aim seems to show a strap or wire between grounds on the horn relay and the regulator also. not sure i understand LH body mount
Old Jan 10, 2006 | 11:03 AM
BarryK's Avatar
BarryK
yep, grounds there also, but not the same ground straps that are included if you buy the ground strap kits.
Without looking at my car, I believe the horn relay and the regular may be grounded together by a single black wire running from the relay to a screw on the case of the regulator - but you should look that up in your AIM since I'm just going by memory.
On the LH bodymount ground, I didn't replace that one since I didn't remove my body, but I think the ground strap goes from the mount bolt to the frame. Doesn't seem to makes since the bolt already goes thru the frame but it probably does make sense when you consider the rubber mount cushions probably isolate the two electrically so the ground strap provides the ground path. i'm not sure which LH bodymount position the ground strap is on though - sorry.
Old Jan 10, 2006 | 01:15 PM
JohnZ's Avatar
JohnZ
The body mount ground strap Barry's referring to is shown in the U69 section of the A.I.M.; one end attaches with a screw and star washer to a hole in the lower front leg of the #1 body mount bracket that's welded to the outside of the frame, and the other end has a U-shaped spring clip with barbs on it that pushes onto the front edge of the body sill that's part of the birdcage.
Old Jan 10, 2006 | 04:43 PM
Chuck Gongloff
That's the way it is on my 63 also. The ground wire is part of the harness. Chuck
Old Jan 10, 2006 | 08:00 PM
gonefishn's Avatar
gonefishn
St. Jude Donor '09
There may be one more. Your profile doesn't have your car listed but if your using shielding, then the distributor upper shield is grounded (extended tab).
John
Old Jan 10, 2006 | 08:21 PM
BarryK's Avatar
BarryK
hi gone
I forgot about that one.
the little extended tab on my shielding that hooks to the air cleaner assembly broke off. Any issues because of that i need to know about or be concerned about? All my other ground straps are good and I just replaced the motor mount and accelerator lever straps. I'd hate to have to spend all that money for a new main shielding cover just because of that little tab piece.
Old Jan 11, 2006 | 12:00 PM
JohnZ's Avatar
JohnZ
Paragon and LICS have the replacement front ground clip and rivets for the upper ignition shield.
Old Jan 11, 2006 | 12:07 PM
BarryK's Avatar
BarryK
cool, thanks John
guess I'll have to order one up on my next parts order
Old Jan 12, 2006 | 09:16 PM
CPR1964's Avatar
CPR1964
Default Come see us!
Come see us at our shop in Mesa at Broadway and Alma School. We have a number of C-2's at various stages of restoration. We have all the manuals and specimans you need to correct your problem!
Tom
www.classicperformancerestoration.com
To ground straps
