well, now that I cleaned up the engine compartment and finally have everything back together I now noticed a greasy spot on the frame rail below the steering box. I HAD cleaned there so I'm sure this is new. I ran my hand along the underside of the box and it came out somewhat oily. Not a lot, but enough to glisten my hand.
I figure the steering box needs looking at.
Is this a job that can be done at home and most importantly by an idiot like me, or is this like trailing arms that are best sent out?
also, I've never opened up the steering box myself yet, but is it supposed to be filled with oil or packed with grease? When I bought the car I was told it was suppose be be grease but the previous owner had oil in it so I should have it drained and repacked with grease but than a mechanic I had used at one point told me there WAS grease in it. I haven't seen for myself either way yet.
Barry read Bill Bradley's article in the Restorer, it is a very good article that covers almost everything. Just because your box is seeping some oil it is not necessary to rebuild. The box that Bill and I rebuilt for my car seeps a little as does his. It's just how it is... btw it's supposed to be filled with grease.. Dave..
The box should have grease so you will not be able to drain it and locla garages probably don't know how to correctly set them up. The bottom seal does wear out and if exposed to headers or BB even more so. How does it feel driving? do you have slop when going down the road? Is your car PS or manual? If you can take apart your car and you have a dial inch pound TW you can rebuild it. I can walk you through both a typical "market" rebuild or even the way I blueprint them.
No problem Barry, I also wrote a paper on rebuilding these. If you would like it email me at gramadei@aep.us and I'll send it. I haven't seen the one you found,is it on a site I can access?
Gary, i'll email you as I'd still like to have other references. the more info the better!
Bill's article was in the Restorer magazine, vol 32, number 1, Summer 2005 issue.
It was written by both Bill Bradley and Duke Williams (SWCDuke). I haven't finished reading it yet but you can imagine any article written by either one of them ,let alone both of those two gentlemen, is going to be right on the money!
according to Bill's article, the original type of grease is discontinued, but the current multi-purpose EP chassis grease (GM # 12377985) can be substituted.
also, according to Bill he say's:
"The recommended grease is NLGI 2 which is like ball joint grease. As a stop gap, if you can find some NLGI 1 grease which is thinner than #2 you may be able to use a large syringe and a tube to get some grease past the sector gear and fill the box for the interim. Worth a try.
Amzoil makes a NLGI 1 grease in tubes like those for a grease gun if you can find an Amzoil dealer to sell you just one tube."
