No, not another sidepipe question!?!?
but bare with me on this one....
I am down to having to make a decision on my 67 L89 project. I am getting the final assembly done for the initial startup, and ran into a snag with my old pipes that came off the car. The passenger side is fine, except for having to weld on the new stainless tip. But the driver side is all banged up. The pipe on the driver side was welded in several spots and doesn't line up at all. Because of the previous repair and welds, it kicks out a little too far coming out at the bend under under the quarter panel and pushes the cover out too much, and then it's about 2 inches too far back at the rear mounting spot. The mounting hole by the rear tire is positioned directly below the large hole in the frame where the mounting bolt is supposed to be positioned and then slid into place for final mounting. Does that make sense? Basically, I think the geometry of the pipe has changed so much that it has been pushed back too much to work. With the new tip slide in place, it almost touches the driver side rear tire and you can't slide the mounting bolt forward in the keyhole, it just hands and falls out of the larger hole.
So, I am thinking of new replacement pipes. I am considering either a set from Allen's, or Sweet thunder.
Finally, here' s a question in all of this...
Does anyone have some sound clips of the these two different pipes? I know they both have sets with slightly larger ID than the stock pipes, so that will help with this motor. I am just not sure how large to go, or which one to choose.I have Youwish stopping by tomorrow night to look it all over and provide some insight on it too. I think another set of eyes will help out and he has alot more knowledge on this than I do.
Thanks for reading my novel and providing some feedback.
Rob
avoid the ss ones, too much 'ting' in them ........
Thanks for your feedback.
Please send it to: rob.harper@sas.com
They are not for the meek and are of excellent quality. I have the Aluminum ones.
Steve
Dan
Thanks everyone for the feedback. I am cool with loud, so that doesn't really bother me. In a perfect world, it would be great to have everyones cars lined up side-by-side to compare. Now that would be sweet!
