Headlight "securing arm/bracket" question
Old Jan 29, 2006 | 07:02 PM
Formula Outlaw's Avatar
Formula Outlaw
Default Headlight "securing arm/bracket" question
On my left headlight, there is this bracket/securing arm/whatever that fits between two rubber gaskets that "locks" the revolving system or whatever you call it down, allowing the headlight to rotate. When it has come loose the headlight will not rotate. I'm having trouble keeping that locking arm in place. It's worked it's way out twice now after reseating it all the way. What have you guys done to keep it in place??? Thanks....
Just another quirk......
Old Jan 29, 2006 | 07:45 PM
vark_wso's Avatar
vark_wso
Your description could use some work ... perhaps you are referring to the "Y" shaped stop bracket that fits on splines over the inboard pivot. If so, it is kept in place by tightening the hex bolt so that the diameter pinches on the pivot shaft. It has 2 adjustable hex bolts -- one that strikes the boss on the inner support when closed & and another that strikes the microswitch when open. There is a flat spot on the splines of the pivot that must align with a radial index mark on the "Y" bracket. This is difficult to accomplish with the hood on the car and the headlight motor in place. You'll likely have to rotate the headlamp housing in order to get the pinch bolt to show itself to tighten (7/16" wrench size).
Old Jan 29, 2006 | 08:16 PM
Formula Outlaw
Sorry, described it as best I could. I'm talking about that flat bracket with the bend in it, oblong hole on the left, and the circular hole with "the opening" that fits between the two rubber gaskets on the right.
The second part from the left in your photograph. Thanks.
Old Jan 29, 2006 | 09:09 PM
vark_wso's Avatar
vark_wso
The small race-track slot to the left in the photo attaches to the headlamp motor (along with the black ground wire) via that small machine screw you see on the motor housing just above the yellowish nylon electrical connector housing. The "C" shaped cut-out fits tightly inside a grommet/spacer assembly that has a slot in it. This grommet assembly is then attached to the (metal) upper body support with a #8-24 hex head machine screw about 1" in length. There's a blind hole for this screw usually kind of hidden by the wiring harness crossing over. Look with a mirror.
It gives the motor some support and a cushion of sorts, but should not affect opening or closing of the headlamp bucket. The lockpin on the inner support (sticking up on the photo) indexes with that U-shaped slot on the motor mount housing (top on photo, right by the red bucket) thus preventing the motor from having any rotational movement.
Old Jan 30, 2006 | 12:07 AM
67L36Driver's Avatar
67L36Driver
You should have a ground wire under the screw securing the bracket to the motor. No ground, no operation.
Old Jan 30, 2006 | 07:08 AM
Formula Outlaw
Thanks guys.....
Old Jan 30, 2006 | 09:25 AM
67L36Driver
Make sure you use a screw only long enough to secure the bracket and ground wire to the motor. A screw with excess length will short out the motor field and fry it. Could be a $400 OOPS.
Old Jan 30, 2006 | 07:00 PM
Formula Outlaw
Thanks for the head's up on the screw length...
Old Feb 2, 2006 | 08:27 AM
Formula Outlaw
Okay, got that issue resolved, duhhhh..... :o
Now the driver's side (same one) headlight starts to rotate then stops. Then I have to get out and handcrank it a little ways, then it will open up electrically. It closes with no problem.
It also operates much slower than the passenger side light.
I'm wondering if the motor is getting weak, the gears have a worn spot in them, or what????
Anybody else dealt with this???
Old Feb 2, 2006 | 10:24 AM
67L36Driver
Boogered teeth on the output gear. Vendors have new ones @ $25 ea. Buy a pair and do the headlite gearbox boogie. Motor likely needs little more than a drop of machine oil on each bearing.
Old Feb 2, 2006 | 10:54 PM
Formula Outlaw
Time to boogie, thanks....
To Headlight "securing arm/bracket" question
