OK-What holds the cigarette lighter in?
1 Post
It's bad when you get down to all the nit picking stuff! Have the lighter out of the car. If you hold it in it will get hot. It just won't stay in by itself. IS IT SUPPOSED TO STAY IN, GET HOT AND POP OUT, OR DO YOU JUST HOLD IT IN? Are the 3 brass prongs supposed to wrap around the ring on the end or what? Mine just touches this ring.
EVERGREEN
It should stay in. You can adjust the female end of the lighter by slightly bending the prongs. Be careful when you do so...disconnect the battery or you might short things out.
By playing with the prongs, you'll get it to stay in, then "POP" when it's hot. Chuck
Originally Posted by BarryK
ironically, I have the opposite problem. I can push mine in, it stays, gets hot, but than will not pop out itself.
thank Chuck, i'll take a look at it.
1 Post
I have it out so I can look at it. The lighter goes in till it just touches the three brass parts. These certainly don't hold it in. The lighter has been with the car the last 30 years that I know of. Is there something in the lighter itself, the spring loaded part, that should click in and lock and then heat up, relax and let the spring go. If so I will take it apart and see whats up.
I also still need someone to tell me the ohm value of the resistor on the heater fan switch!!
chuck, except for a couple test drives since I got the motor back together the battery has been disconnected most of the winter
you know working on cars mechanically is new to me, but I spent years doing car audio so usually the VERY FIRST thing I touch on a car when working on it is the battery ground cable to disconnect it.
as I've said for years.......... i may be dumb, but I'm not stupid.
oh, and I'd prefer the lighter just popped out to it's normal position rather than flying across the car into my seats, chest, lap, whatever!
If you have the original Casco 63, you need a "female" to match, OR if you have another model Casco, like a 78, you need the female for that. Chuck
Received 1,859 Likes
If you have a recent replacement/restoration Casco lighter housing (made in the last five years or so), it has a U-shaped bi-metallic element under the nut on the feed connector stud that's designed to dead-short the lighter internally if it gets too hot (from having too much stuff plugged into it for power) so it doesn't melt plastic instrument panels in modern cars. That internal dead-short blows the lighter fuse. However, in Corvettes, pre-'67 cars don't have a fuse on that circuit, and if the lighter dead-shorts internally, it will fry the harness all the way to the battery, and can start a fire that will burn the car to the ground. If you have one of these newer lighter housings, either install an in-line fuseholder in the red feed wire or remove the U-shaped bi-metallic shorting element (see photo below).
I got hold of a new casco lighter ***'y (Lighter and socket) but I can't seem to remove the old socket. Cannot turn the back (behind the dash) without the front spinning. Any suggestions?
Thanks,
Vinny
Thanks,
Vinny
Take the lighter out, stick your thumb in the housing to hold it stationary, and unscrew the housing retainer on the back (after disconnecting the feed wire and light bulb socket, and disconnecting the battery ground cable).
Sounds like an in-line fuse is a good idea regardless
I for one will be installing an in-line fuse in my car, NCRS correct or not, I don't need a fire after all these years of work due to a lighter circuit.
