Hello I Have A 1965 Nassau Blue, Bright Blue Coupe 327/250 4 Speed That I Have Owned For About 20 Years I Think It Is The Original Engine But Is There Some Place I Can Get The Information As To Just What All The Numbers Should Be As It's Getting Time To Do A Frame Off And I Want To Make Sure Every Thing Is Up To Snuff It Is The 680th Car Produced In 1965 But Some Of The Numbers I See Are For August And September Of 1964 (such As Gauge Cluster) Also The Engine Block Is 870 But What About Heads ? Etc. Starter,water Pump Alternater.
