Diff. Tag
Old Feb 18, 2006 | 07:19 AM
Michaelw's Avatar
Michaelw
Default Diff. Tag
Hello,
is there a difference between the tag which can be found ona non posi differential for a 64 and 65?
Groeten,
Old Feb 18, 2006 | 04:42 PM
JohnZ's Avatar
JohnZ
There is no tag on a non-posi differential.
Old Feb 20, 2006 | 01:04 PM
Michaelw's Avatar
Michaelw
JohnZ,
Thanks for the feedback, but maybe I forumalted my question wrong.....on the picture below there is a tag , is this tag for a 64 or 65 non poss. diff?
Thanks in advance for the anwser
Regards
Michael
Old Feb 20, 2006 | 01:52 PM
JohnZ's Avatar
JohnZ
That metal tag was used on '63-'64 Posi diffs; non-posi diffs had no tag.
Old Feb 20, 2006 | 04:31 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
That looks like a 63-64 posi lube tag. It's not a "ratio tag". Chuck
Old Feb 21, 2006 | 03:28 AM
Michaelw's Avatar
Michaelw
Chuck and JohnZ thanks for the input.
This is a pic of the tag on my diff. My car is a 65 and the rear axle has drum brakes. Is it safe to draw the conclusion that my 65 has a 63 or 64 axle on the rear?
Fyi: front has disk brakes. The back of the body shows no sign of damage happended in the past (only a recent damage ).
Regards
Mike
Old Feb 21, 2006 | 09:27 AM
achapman's Avatar
achapman
Regards
Mike
There was a few 65's that had drum brakes, but none that had disk and drum. I suggest you check the VIN number under the glove box, then check for the frame VIN. Just above the rear tire on the drivers side, using a small mirror you should be able to see the VIN number on the frame. You may have to do some cleaning and scraping, but once you find it you should be able to compare the numbers to see if indeed the frame replaced in the past.... Good Luck.....
Old Feb 21, 2006 | 12:21 PM
JohnZ's Avatar
JohnZ
This is a pic of the tag on my diff. My car is a 65 and the rear axle has drum brakes. Is it safe to draw the conclusion that my 65 has a 63 or 64 axle on the rear? Mike
The ratio code and assembly date is stamped on the bottom of the diff housing, between the spring retainer plate and the camber strut rod bracket; take a look and tell us what letters/numbers you see there.
Old Feb 21, 2006 | 04:00 PM
Michaelw's Avatar
Michaelw
JohnZ I checked that place an no numbers, even after cleaning
I will double check again next week when I have some more time.
To Diff. Tag
