cov deck lid
Old Mar 7, 2006 | 03:12 PM
66 big block's Avatar
66 big block
Default cov deck lid
Iwas trying to find way to bring rear of deck lid down I see front adjustment but rear hinges dont seem to have anyway to adjust thanks John
Old Mar 7, 2006 | 03:33 PM
JSB69's Avatar
JSB69
Put shims under the front bolt on the hinge to bring the rear edge down, readjust the latches as needed.
Old Mar 7, 2006 | 06:37 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
The way I did mine was to unhook the springs, close the deck lid and unbolt the hinges. With a buddy holding the deck lid in the desired location, I positioned the hinges one at a time against the bottom of the deck lid. If the hinge doesn't fit flush, fill any gap with shims and bolt the hinge back on. Then do the same with the other hinge. To make the job somewhat easier, I removed a seat. Position the deck lid somewhat lower than your desired height as it will come up a bit when you reinstall the springs.
Old Mar 7, 2006 | 11:56 PM
wombvette's Avatar
wombvette
Yep, just shim under the front bolt.
To cov deck lid
