proper resistor voltage
Old Mar 20, 2006 | 04:29 PM
acowboy's Avatar
acowboy
Default proper resistor voltage
installed a 383 in the car, and around 4800 rpm had ignition stumbles....checked the voltage on the stock (250 hp) resistor, and only had 4.5 V on coil side...put a new one on, and now has 10.3 V on coil side, down from 13.5 at ign wire...car pulls good to 6000 rpm, but, am wondering if that many volts will eat points...always thought resistor should carry around 7-8 V....what do you guys think??
Old Mar 21, 2006 | 01:42 PM
JohnZ's Avatar
JohnZ
Disconnect the wires from the resistor and check the resistance across the terminals - should be 1.7-2.3 ohms. Voltage at the coil (+) terminal can only be checked accurately with the engine running.
Old Mar 21, 2006 | 04:22 PM
acowboy's Avatar
acowboy
yea,,john...had engine running when did check...was getting 10.4 V to coil...sounds like too much to me...will check ohms....thanks
To proper resistor voltage
