Bouncing Tach
Old Mar 24, 2006 | 08:53 PM
maddoe's Avatar
maddoe
Default Bouncing Tach
I have a 67 390 and the tach needle has suddenly started to bounce. It seems to be most prevalent when decelerating and revving the engine. At idle and constant speed it's fine. I know I have seen others on the forum with this problem in the past but I wasn't able to find anything in a search. Any suggestions on a cause/fix would be appreciated.
Old Mar 24, 2006 | 10:50 PM
1KULC7's Avatar
1KULC7
Veteran: Coast Guard
Time for a new cable...usually the gears are worn.
Old Mar 24, 2006 | 11:04 PM
Solidlifters
Sometimes a good greazin' of the inner cable will make it behave. Dry cables have a tendency to chatter.
Old Mar 25, 2006 | 08:33 AM
garth64's Avatar
garth64
Lubricate the lower 3/4's of the cable first before replacing it.
Old Mar 25, 2006 | 12:05 PM
JohnZ's Avatar
JohnZ
Yank the distributor and unscrew the coupler - if the cross gear and mainshaft gear look like the photo below, it's time to replace them both. If you only replace the cross gear, the new one will be eaten up in no time.
Old Jun 26, 2020 | 11:50 AM
tuxedo's Avatar
tuxedo
I am pretty sure I have this problem. Everything behind that distributor is new or been redone. I think I will unhook the cable and spin the cable with a drill to see if the tach needle moves normally. Then yank the distributor if that needle moved normally with the drill.
To Bouncing Tach
