I've took my dash cluster apart today to find out why my odometer is not working! Turn out to be the little worm inside the speedometer gauge that is connected to the odometer gear! Does anyone know where i could find another one. Thanks
As far as I know, GM has discontinued all of these mechanical speedometer and tachometer parts, which were otherwise available until recently. I do not know of any other current source for these parts. You might try calling Instrument Services Co. of Roscoe, IL or Corvette Clocks by Roger of Jackson, TN They will likely know the status of parts availabilty.
