actually, does anyone know what the dome volume of a .030 over 327 SHP piston is? the 327-365 motor i'm referring to.
i just got my heads CCed and they are 60cc chambers, .030 over 327 and I"m running the .015 embossed/coated steel head gasket from felpro... deck heigth is stock.
any ideas?
thanks
Aaron
The speed pro F/M pistons that I am going to use are +.020 over / .125 dome. = 5.3 CC
With my deck height (.026), and I have not CC'd the heads yet, I am looking at .040 head gasket to get 10.5:1
Anymore then 10.5:1 and you are going to need more then pump gas.
i was hoping to be over 11 to 1. I'm running all stock componants but the cam... which still needs 10 to 1 to work correctly, and if I ever decide to put the stock 30-30 back in, i wanted the 11.50 to 1 that these motors should have originally had.
