Front Coil Spring Question
Well, I was tearing apart my front end to install new A-Arm bushings and ball joints so I decided to replace springs also. Got replacements at the local auto parts store. They had them at a decent price and they are listed as specific to my Corvette-1967, 327, no A/C, 4 spd.
Question-Does anyone have a spec or reference to the spec for the front coil springs? The ones that were in there were 12 coil, 16" tall. The replacements are 6 coil, 12.25" tall. They are the ones listed for this application, don't know if the old ones are original.
I just want to verify if they are correct before I put them in. It will be a while before engine and all other components are in to add weight to the front end. I checked Noland Adams' book and several other restoration guides, but found no info on how tall or how many coils these should have. They may work fine if they have the same spring rate and installed height.
Any help is appreciated.
tc
Front Spring Part# 3851100
Type - Right Hand Helix
Cut-Off Length - 168.50"
Number of coils (active 10.67) (total 12.00)
Wire Diameter - .600"
Outside Dia. at ends - 5.19"
Pitch Dia - 4.40"
Height (Free 15.40")
The replacement specs don't match any original midyear spring; possibly the spring rate and ride height are acceptable, but who knows?
Sounds to me like the ones you took out were probably original standard springs, and still close to spec... are you sure you wish to replace them?
You might check with eatonsprings.com ...I think they are a licensed "GM Restoration Parts Dealer" and they made the original springs for GM.
