Ballast Resistor???
Old Apr 9, 2006 | 12:04 AM
saopm's Avatar
saopm
Default Ballast Resistor???
What does the Ballast Resistor on the ignition system do? I’m running a Pertronix Ignitor setup. Do I still need the resistor?
Old Apr 9, 2006 | 12:19 AM
62Jeff's Avatar
62Jeff
Here's an old thread that resulted in some good information about ballasts and Pertronix
http://forums.corvetteforum.com/show....php?t=1267459
Old Apr 10, 2006 | 11:03 AM
magicv8's Avatar
magicv8
No.
I use one terminal of the resistor as a terminal block - wth all the 12volt ignition wires (including Pertronix) on it. Of course I also have a Pertronix coil, so that I can use resistor spark plug wires with resistor plugs - and not worry about overloading the old original coil.
Old Apr 10, 2006 | 02:00 PM
Tom Piper's Avatar
Tom Piper
If you read JohnZ's post on the link above, he hit it right on the head.
The only thing I want to add is the stock coil was designed for a maximum of 2/10ths volt being dropped across the point resistance.
In this case, since the Pertronix replaces the points, if you are using the stock coil with the Pertonix electronics, you don't want the Pertronix dropping more than 2/10ths of a volt either.
Tom Piper
Old Apr 10, 2006 | 10:18 PM
K2's Avatar
K2
If you are using the Pertronics Flamethrower coil you don't need the resistor as the coil has an internal resistance of 1.5 ohms already. If you are using the stock coil you will need to retain the external resistor. If you are using the Flamethrower coil and retain the resistor you will have way too much resistance with resultant low voltage to the coil. The Pertronics instructions also state this although they are not the most clearly written instructions I've ever seen.
Old Apr 10, 2006 | 10:31 PM
pletner's Avatar
pletner
Does anyone have any experience with the Mallory Unilite Distributor and Mallory Coil? Do you still use the ballast resistor? I'm getting ready to do this install and I'd like to hear from anyone who has done this before.
Old Apr 10, 2006 | 10:40 PM
longbros's Avatar
longbros
The primary function of the ballast resistor in the ignition system is to be a protective device. If key is on, and the engine is not running, the ballast resistor limits the current through the coil and points, should the points be closed with the engine stopped. In this situation, the ballast resistor will rapidly heat up and the resistance will increase, thus protecting your coil and points. These resistors are of such a low resistance value, that they have little effect at normal running conditions, but they do have an effect. It makes sense, that under normal running conditions, a higher value ballast resistor would increase point life.
I can't address the Pertronix application as I don't have one and know nothing about them.
Old Apr 10, 2006 | 10:50 PM
saopm's Avatar
saopm
Thanks for the info, all. This is the coil I have. Can't tell if it need the resistor or not. I don't have points so i guess it can go.
Product Line: PerTronix Flame-Thrower II Ignition Coils
Coil Wire Attachment: Female/Socket
Coil Style: Canister
Coil Internal Construction: Oil-filled
Maximum Voltage: 45,000 V
Turns Ratio: 100:1
Primary Resistance: 0.600 ohms
Secondary Resistance: 10K ohms
Inductance: 7.2 mH
Peak Current: 7.2 amps
Spark Duration: 1.5 mS
Mounting Bracket Included: No
Coil Wire Included: No
Ballast Resistor Included: No
Coil Color: Black
Coil Shape: Round
Diameter (in): 2.125 in.
Height (in): 6.000 in.
Quantity: Sold individually.
Notes: For use with the Pertronix Ignitor II ignition. Can also be used with other Capacitive Discharge (CD) induction ignition systems.
Old Apr 10, 2006 | 10:56 PM
62Jeff's Avatar
62Jeff
Turns Ratio: 100:1
Inductance: 7.2 mH
Coil Color: Black
Coil Shape: Round
I have that coil and that version of the Pertronix on my 62, and bypassed the ballast resistor.
Old Apr 11, 2006 | 01:12 AM
K2's Avatar
K2
Looking at the Pertronix web site specifically the Flamethrower II system and coil, it is not specific with regard to elimination of resistor. The Flamethrower II coil is only .6 ohm resistance and apparently is compatible with the Flamethrower II module. I'm running the standard module with 40,000 volt Flamethrower coil with no resistor and have experienced no problems. Might be worth sending them an e-mail confirming application with Flamethrower II system.
To Ballast Resistor???
